MATX27
Bulk Data Entry Defines additional material properties for elastic-plastic brittle material for geometric nonlinear analysis.
| MATX27 | MID | A | B | N | EPSMAX | SIGMAX | C | DEPS0 | |
| ICC | |||||||||
| EPS1 | EPS1MAX | D1MAX | EPSD1 | EPS2 | EPS2MAX | D2MAX | ESPD2 |
| MAT1 | 127 | 60.4 | 0.33 | 2.70E-06 | |||||
| MATX27 | 127 | 0.09026 | 0.22313 | 0.374618 | 100.0 | 0.175 |
| MID | Material ID of the
associated MAT1. 1 No default (Integer > 0) |
| A | Plasticity yield
stress. (Real > 0) |
| B | Plasticity hardening
parameter. (Real ≥ 0) |
| N | Plasticity hardening
exponent. Default = 1.0 (Real ≤ 1.0) |
| EPSMAX | Failure plastic strain
. Default = 1030 (Real > 0) |
| SIGMAX | Maximum plastic stress
| C | Strain rate
coefficient. Default = 0.0 (Real) |
| DEPS0 | Reference strain rate
. Default = 0.0 (Real) If DESPS ≤ DESPS0, no strain rate effect. |
| ICC | Strain rate dependency of
flag. 4
| EPS1 | Tensile failure strain in
principal strain direction 1. Default = 1.0*1030 (Real > 0) |
| EPS1MAX | Maximum tensile failure
strain in principal strain direction 1. Default = 1.1*1030 (Real > 0) |
| DMAX1 | Maximum tensile failure
damage in principal strain direction 1. Default = 0.999 (Real > 0) |
| EPSD1 | Tensile strain for element
deletion in principal strain direction 2. Default = 1.2*1030 (Real > 0) |
| EPS2 | Tensile failure strain in
principal strain direction 2. Default = 1.0*1030 (Real > 0) |
| EPS2MAX | Maximum tensile failure
strain in principal strain direction 2. Default = 1.1*1030 (Real > 0) |
| DMAX2 | Maximum tensile failure
damage in principal strain direction 2. Default = 0.999 (Real > 0) |
| EPSD2 | Tensile strain for element
- The material identification number must be that of an existing MAT1 Bulk Data Entry. Only one MATXi material extension can be associated with a particular MAT1.
- MATX27 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS=EXPDYN. It is ignored for all other subcases.
- This law is only applicable with shell elements. The isotropic elasto-plastic model is the same as with MATX02. However, MATX27 allows material damage and brittle failure to be modeled.
- ICC controls the strain rate effect.
Figure 1. - The failure plastic strain EPSMAX has no effect if the second continuation is defined.
- An element is removed if one layer reaches
the tensile failure strain EPS1.
Figure 2. - This card is represented as an extension to a MAT1 material in HyperMesh.
