MATX02
Bulk Data Entry Defines additional material properties for Johnson-Cooke elastic-plastic material for geometric nonlinear analysis. This is an elasto-plastic law with strain rate and temperature effects.
| MATX02 | MID | A | B | N | EPSMAX | SIGMAX | C | DEPS0 | |
| ICC | FSMOOTH | FCUT | M | TMELT | RCP |
| MAT1 | 102 | 60.4 | 0.33 | 2.70E-06 | |||||
| MATX02 | 102 | 0.09026 | 0.22313 | 0.374618 | 100.0 | 0.175 |
| MID | Material ID of the associated MAT1. 1 No default (Integer > 0) |
| A | Plasticity yield stress. (Real > 0) |
| B | Plasticity hardening parameter. (Real ≥ 0) |
| N | Plasticity hardening exponent. Default = 1.0 (Real ≤ 1.0) |
| EPSMAX | Failure plastic strain
Default = 1030 (Real > 0) |
| SIGMAX | Maximum plastic stress
| C | Strain rate coefficient. If zero, there is no
strain rate effect. Default = 0.0 (Real) |
| DEPS0 | Reference strain rate
. Default = 0.0 (Real) If DESPS ≤ DESPS0, no strain rate effect. |
| ICC | Strain rate dependency of
flag. 5
| FSMOOTH | Strain rate smoothing flag.
| FCUT | Cutoff frequency for strain rate filtering. Only
for shell and solid elements. Default = 1030 (Real ≥ 0) |
| M | Temperature exponent. Default = 0.0 (Real) |
| TMELT | Melting temperature. Default = 1030 (Real > 0) |
| RCP | Specific heat per unit of volume. Default = 0.0 (Real ≥ 0) |
- The material identification number must be that of an existing MAT1 Bulk Data Entry. Only one MATXi material extension can be associated with a particular MAT1.
- MATX02 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS=EXPDYN. It is ignored for all other subcases.
- This
is an elastic-plastic law with strain rate and thermal effects. It
follows:
(1) Where,(2) Where,- Plastic strain
- Strain rate
- Temperature (in Kelvin)
- If the plastic strain reaches EPSMAX, shell elements are deleted. Solid elements are not deleted, but the deviatoric stress is set to zero.
- ICC controls the strain rate effect.
Figure 1. - No strain rate effects are considered in rod elements.
- Strain rate filtering is used to smooth strain rates. The input FCUT is available only for shell and solid elements.
- To take into account the temperature effect, strain rate dependence must be activated. If the temperature exponent M=0; there is no temperature effect. No temperature effect is considered on rod, bar, and beam elements.
- The
temperature is computed assuming adiabatic conditions:
(3) Where, Eint is the internal energy.
If = 0, the temperature is constant .
- This card is represented as an extension to a MAT1 material in HyperMesh.
