CTAXI
Bulk Data Entry Defines an axisymmetric triangular cross-section ring element.
CTAXI EID PID G1 G2 G3 G4 G5 G6
  Theta
CTAXI 111 2 31 74 75 32 51 52
  15.0
EID Unique element identification number.
No default (Integer > 0)
PID A PAXI entry identification number.
Default = EID (Integer > 0)
G1, G3, G5 Identification numbers of connected corner grid points (by default). Cannot be omitted. See SYSSETTING,AXEGORD for more information.
No default (Integers > 0, all unique)
G2, G4, G6 Identification numbers of connected edge grid points (by default). Can be omitted. See SYSSETTING,AXEGORD for more information.
Default = blank (Integers > 0, all unique)
Theta Material orientation angle in degrees.
Default = 0.0 (Real)
  1. All the grid points must be in the x-y plane or in the x-z plane of the basic coordinate system with x = r ≥ 0. The grid points must be ordered consecutively starting at a corner grid point and proceeding around the perimeter in either direction.
    Corner grid points G1, G3 and G5 must be present. The edge points G2, G4 and G6 are optional. If any of the edge points are present, they all must be used.
    Note that this information is consistent only for the default SYSSETTING,AXEGORD,0. If this is switched to 1, then the corresponding grid point references should be interpreted accordingly.
    ctriax6
    Figure 1. CTAXI Definition
  2. The continuation line is optional.
  3. If the PAXI entry referenced in field 3 references a MAT3 entry, material properties and stresses are always given in the (xm, zm) coordinate system shown in the figure above.
  4. A concentrated load (for example, the load specified on a FORCE entry) at a grid Gi of this element denotes that applied onto the circumference with radius of Gi. For example, in order to apply a load of 200N/m on the circumference at Gi which is located at a radius of 0.4m, the magnitude of the load specified on the static load entry must be:(1)
    ( 200   N / m ) * 2 π * ( 0.4 m ) = 502.655 N
  5. CTAXI and CTRIAX6 elements cannot be used simultaneously in an input model.
  6. Axisymmetric elements are supported for linear analysis, small and large displacement nonlinear static analysis. Currently, axisymmetric elements are not supported for inertia relief analysis in large displacement nonlinear analysis.
  7. The element grids numbering scheme is controlled by SYSSETTING,AXEGORD,0/1.
    SYSSETTING,AXEGORD Corner Grid Points Edge Grid Points
    C1 C2 C3 C4 E1 E2 E3 E4
    0 (default) G1 G3 G5 G7 G2 G4 G6 G8
    1 G1 G2 G3 G4 G5 G6 G7 G8
  8. This card is represented as an element in HyperMesh.
