TABLEMD
Bulk Data Entry Defines a multi-dimensional tabular function which identifies single or multiple X-values for a single Y-value.
| TABLEMD | TID | LABEL | NDEP | FLAT | |||||
| Y1 | X1_1 | X1_2 | X1_3 | etc | etc | etc | X1_7 | ||
| X1_8 | etc | X1_10 | |||||||
| Y2 | X2_1 | X2_2 | X2_3 | etc | etc | etc | X2_7 | ||
| X2_8 | etc | X2_10 |
| TABLEMD | 32 | 6 | |||||||
| -3.0 | 6.9 | 2.0 | 5.6 | 3.0 | 5.6 | 11.2 | |||
| 2.0 | 5.2 | 3.0 | 1.0 | 22.1 | 5.3 | 9.2 |
| TID | Table identification
number. No default (Integer > 0) |
| LABEL |
| NDEP | Identifies the number of
dependencies (Xi_j) defined for each
Yi value. No default (Integer > 0 and ≤ 10) |
| Yi | Yi
values. No default (Real or ENDT) |
| Xi_i | Xi
values for each corresponding Yi value. 4 No default (Real or ENDT) |
| FLAT | Specifies the handling
method for looking up yi-values when specified xi is outside the
range of xi-values in the table.
Default = 1 |
- At least one continuation entry must be specified.
- When TABLEMD is used in OSTTS damage calculations, NDEP=1 should be specified. The Xi_j values should be specified in ascending order only.
- String-based labels allow for easier visual identification of TABLEMD, including when being referenced by other entries (for instance, the TID field of material data like MATS1 and MATF entries). Refer to the String Label Based Input File for more information.
- For a particular Yi, if certain Xi_j fields are blank on the TABLEMD entry, the default value for such Xi_j is set as 0.0. The final Xi_j value defined for a particular Yi should not be left blank.
