MATT1EC
Bulk Data Entry Defines temperature-dependent material properties for the corresponding MAT1EC Bulk Data Entry fields via TABLEMi or TABLEG entries.
| MATT1EC | MID | T( ) | T(JH) |
| MATT1EC | 24 | 200 |
| MID | Material identification number of a
MAT4 Bulk Data Entry that is temperature
dependent. No default (Integer > 0) |
| T( ) | Identification number of a
TABLEMi or TABLEG
entry that defines temperature-dependent electrical resistivity.
Default = 0 (Integer ≥ 0) |
| T(JH) | Identification number of a
TABLEMi or TABLEG
entry that defines temperature-dependent Joule heating fraction.
- The quantities defined on the MAT1EC Bulk Data Entry are multiplied by the tabular function referenced by the MATT1EC Bulk Data card to generate the corresponding material properties.
- If the fields are blank or zero, constant properties defined on the MAT1EC Bulk Data card are used.
