CNTITF
Bulk Data Entry Defines parameters for contact (S2S and N2S) interference.
This entry is supported with nonlinear static and nonlinear transient analysis types for both small and large displacement analysis. The CNTITF Bulk Data Entry should be referenced by a CNTITF Subcase Information Entry to be applied in a particular subcase.
CNTITF | ID | METHOD | H1 |
CNTINT | CTID | METHOD | H1 |
CNTITF | 98 | INST | |||||||
CNTINT | 51 | INCR | |||||||
CNTINT | 52 | 222 |
Definition
ID | Each CNTITF Bulk Data Entry should have a
unique ID. No default (Integer > 0) |
METHOD | Flag indicating how contact interference is applied.
H1 | The amount of allowable penetration, which will not be
resolved in the subcase and its continued subcases. Contact with
penetration smaller than this value is considered as open.
(Real ≥ 0.0)
Note: The H1 field should
be blank, if METHOD field is set to
INST or a table
ID.
CNTINT | Defines the start of a continuation line used to specify another set of interference parameters, which overrides the set of parameters defined above, for a specific contact interface (CTID). It can be repeated as required. | |
CTID | Contact interface identification number. No default (Integer > 0) |
- The CNTITF Bulk Data Entry is selected by the CNTITF Subcase Information Entry.
- TABLES1 and TABLEG can be referenced in METHOD field. In the table, time and factor are defined in X- and Y- column, respectively. The factors are multiplied on the initial penetration amount to indicate the restored penetration amount at the specified time. The y-value of the last point specifies the ratio of the allowable penetration over the initial penetration in the following subcases. The y-value of the first points must be 1.0.
- When a CNTITF card is not defined, initial contact penetration of all N2S and S2S contact will be resolved in the root subcase, which is equivalent to METHOD = INCR and H1 as blank.
