MATX70
Bulk Data Entry Defines additional material properties for tabulated visco-elastic foam material for explicit dynamic analysis.
| MATX70 | MID | EMAX | EPSMAX | FSMOOTH | FCUT | NLOAD | NULOAD | IFLAG | |
| SHAPE | HYS |
| TIDL | EPSRL | FSCALL |
| TIDU | EPSRU | FSCALU | |||||||
| SHAPE | HYS |
| MATX1 | 170 | 0.1 | 0.1 | 9.9E-07 | |||||
| MAT70 | 170 | 1.0 | 0.8 | 1 | 4 | ||||
| 2 |
| MID | Material ID of the associated
MAT1. 1 No default (Integer > 0) |
| EMAX | Maximum young modulus. (Real > 0) |
| EPSMAX | Maximum plastic (failure) strain. (Real > 0) |
| FSMOOTH | Strain rate smoothing flag.
| FCUT | Cutoff frequency for strain rate filtering.
Default = 1.E30 (Real ≥ 0) |
| NLOAD | Number of loading stress-strain
function. Default = 1 (Integer ≥ 1) |
| NULOAD | Number of unloading stress-strain function. If
IFLAG in this card is
1, 2,
3, or 4,
NULOAD must be
0. Default = 1, if IFLAG = 0 Default = 0, if IFLAG = 1, 2, 3, 4 (Integer > 0) |
| IFLAG | Flag
to control the loading/unloading behavior. 5
(Integer) |
| SHAPE | Shape factor. Default = 1.0 (Real) |
| HYS | Hysteresis unloading factor. Default = 1.0 (Real) |
| TIDL | Identification number of
TABLES1 entry that defines the
loading function. (Integer > 0) |
| EPSRL | Strain rate for loading function. Default = 0.0 (Real) |
| FSCALL | Scale factor for loading function. Default = 1.0 (Real) |
| TIDU | Identification number of
unloading function. No default (Integer > 0) |
| EPSRU | Strain rate for unloading function. Default = 0.0 (Real) |
| FSCALU | Scale factor for unloading function. Default = 1.0 (Real) |
- The material identification number must be that of an existing MAT1 Bulk Data Entry. Only one MATXi material extension can be associated with a particular MAT1.
- MATX70 is only applied in explicit dynamic analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
- This material law can be used only with solid elements. The corresponding PSOLIDX property must define ISOLID = 1 (Belytschko element), ISMSTR = 1 (small strain), and IFRAME = OFF (not co-rotational).
- The loading and unloading
functions use engineering stress-strain curve.
Figure 1. Loading and Unloading Stress-Strain Curves - The loading
and unloading behavior is determined by IFLAG.
- IFLAG = 0 - The material behavior follows the defined curves for loading and unloading. NLOAD and NULOAD must be greater than 0.
- IFLAG = 1 - Both loading curves are
used respectively. For unloading, the deviatoric
stress is modified by using the quasi-static
unloading curve.
(1) Where, is calculated from the quasi-static unloading curve.
are the current stresses computed respectively from the unloading and quasi-static curves.
The pressure is:(2) - IFLAG = 2 - Both loading and
unloading curves are used respectively. For
unloading, the stress tensor is modified using the
= (1 -
D)
, where, D is calculated from
- IFLAG = 3 - The loading curves are
used for both loading and unloading behavior. The
unloading curve is ignored. The deviatoric
unloading stress is modified
using:
(3) (4) Where, Wcur and Wmax are the current and maximum energy, respectively.
- IFLAG = 4 - The loading curves are
unloading curve is ignored. The unloading stress
(5) Where, Wcur and Wmax are the current and maximum energy, respectively.
- For IFLAG = 3, 4 the unloading curves are not used
- For stresses above the last load function, the behavior is extrapolated by using the two last load functions. In order to avoid huge stress values, it is recommended to repeat the last load function.
- When maximum plastic strain EPSMAX is reached, EMAX is used whatever the curve definition is.
- If EMAX is blank, EMAX is set and equal to Young modulus on MAT1 card.
- If EPSMAX is blank, it will be calculated automatically if EMAX is less than the maximum tangent according to the input stress-strain curves.
- Young's modulus E on MAT1 card would be modified automatically if it is less than the initial value according to the input stress-strain curves' tangents.
- This card is represented as a material in HyperMesh.
