RWALADD
Bulk Data Entry Defines a rigid wall set as a union of rigid walls defined via RWALL entries.
| RWALADD | SID | S1 | S2 | S3 | S4 | S5 | S6 | S7 | |
| S8 | S9 | etc. |
| RWALADD | 101 | 2 | 3 | 1 | 6 | 4 |
| SID | Set identification number. (Integer > 0) |
| Sj | Set identification numbers of rigid wall
sets defined via RWALL entries. Must be unique and may not be the
identification number of a rigid wall set defined by another
RWALADD entry. (Integer > 0) |
- Multipoint constraint sets must be selected with the Subcase Information command RWALL=SID.
- RWALADD entries take precedence over RWALL entries. If both have the same SID, only the RWALADD entry will be used.
- This card is represented as a load collector in HyperMesh.
