RWALL
Subcase Information Entry The RWALL command can be used to select rigid walls for Explicit Dynamic Analysis.
RWALL = option
- Only one RWALL entry can be present for each subcase. It can only be used in subcases that contain an ANALYSIS = EXPDYN entry.
- If the SID referenced by the RWALL Subcase Information Entry matches with the SID defined for an RWALADD Bulk Data Entry, the information on this entry alone is selected. However, if a RWALADD Bulk Data Entry does not have the referenced SID defined, then any XHSIT Bulk Data Entries that have this SID defined will be selected.
