MODTRAK
Subcase Information Entry The MODTRAK command can be used to control mode tracking.
MODTRAK = option
| Argument | Options | Description |
| option | <ON, OFF, blank> |
- MODTRAK entry is only valid for normal modes subcases.
- If a MODTRAK entry is present in the input, then PARAM, MODETRAK is ignored.
- Positive integers are accepted as option, and are interpreted as ON.
- Negative integers or 0 are not accepted as an option and will result in an error termination.
