MKAERO1
Bulk Data Entry To input a table of Mach numbers (M) and reduced frequencies (K) for aerodynamic matrix calculation, in unsteady aerodynamic analysis.
MKAERO1 | M1 | M2 | M3 | M4 | M5 | M6 | M7 | M8 | |
K1 | K2 | K3 | K4 | K5 | K6 | K7 | K8 |
MKAERO1 | 0.3 | 0.69 | |||||||
0.010 | 0.033 | 0.067 | 0.201 | 0.335 | 0.470 | 0.604 | 0.671 |
Definition
Mi | Value of Mach number. No default (Real ≥ 0.0) |
Kj | Value of reduced frequency. No default (Real > 0.0) |
- Aerodynamic matrices will be computed using all combinations of Mach number and reduced frequency pairs (Mi, Kj) from the table. This is different from MKAERO2, where aerodynamic matrices will be computed only using the defined set of pairs (Mi, Kj).
- In case of MKAERO1, the continuation line (Kj) is required. This is different from MKAERO2 where the continuation line is not allowed.
- Multiple MKAERO1 entries are allowed.
- To obtain accurate results in Doublet-Lattice Method (DLM), it is
recommended to ensure that Kj values satisfy the
following relationship.
(1) Where,- Reference chord length (REFC field in AEROS entry).
- Representative box chord length in the panel mesh.
- This entry is supported only with Flutter Analysis.
