PBARX
Bulk Data Entry Defines additional BAR properties for geometric nonlinear analysis.
| PBARX | PID | ISMSTR | ISTRAIN | DM | DB |
| PID | Property identification number of the associated
PBAR or
PBARL card.
1 No default (Integer > 0) |
| ISMSTR | Small strain formulation flag.
(Integer) |
| ISTRAIN | Shear in beam formulation flag.
| DM | Beam
membrane damping. Default = 0.0 (Real ≥ 0) |
| DB | Beam
bending damping. Default = 0.01 (Real ≥ 0) |
- The property identification number must be that of an existing PBAR Bulk Data Entry. Only one PBARX property extension can be associated with a particular PBAR.
- PBARX is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
- This card is represented as an extension to a PBAR property in HyperMesh.
