MBSFRCC
Bulk Data Entry Defines a curve scalar load on two grid points.
MBSFRCC | SID | G1 | G2 | CVID | INT | EID |
MBSFRCC | 3 | 345 | 346 | 1 | AKIMA | 1 |
SID | Load set
G1 | Grid point
G2 | Grid point
CVID | Set identification
number of the MBCRV entry that gives the load
versus independent variable measured in the coordinate system
defined by CID. (Integer > 0) |
INT | Interpolation type.
(Character) |
EID | Set identification
number of the MBVAR for
the independent variable expression. Default = TIME (Integer ≥ 0 or blank) |
- MBSFRCC applies a translational action-reaction force along the line of action defined by the line segment connecting G1 and G2.
- The action force is applied to G1 and the reaction force is applied to G2.
- Tensile force is positive.
