MATTVP
Bulk Data Entry Defines temperature-dependent material properties for the corresponding MATVP Bulk Data Entry fields via TABLEMi or TABLEG entry.
| MATTVP | MID | T(A) | T(n) | T(m) |
| MATTVP | 2 | 200 | 201 | 202 |
| MID | Material identification number of a
MATTVP Bulk Data Entry that is temperature dependent. No default (Integer > 0) |
| T(A) | A TABLEMi or
TABLEG entry identification number for the parameter
A. (Integer ≥ 0 or blank) |
| T(n) | A TABLEMi or
n. (Integer ≥ 0 or blank) |
| T(m) | A TABLEMi or
m. (Integer ≥ 0 or blank) |
- The value in a particular field of the MATVP entry is replaced (if TABLEM1 or TABLEG is used) or modified (if TABLEM2/3/4 is used) by the table referenced in the corresponding field of this entry.
- If the fields are blank or zero, then constant properties defined on the MATVP Bulk Data card are used.
