Bulk Data Entry This parameter controls the output of the force-deflection curve in geometric
nonlinear analysis.
Parameter |
Values |
Description |
SNAPTHRU |
YES,
NO |
PARAM,
SNAPTHRU controls the output of the
force-deflection curve in geometric nonlinear analysis.
- YES
- The converter will generate rigid bodies internally and
output the time history for rigid body forces in the
Time-History (TH) file. This is valid only when grids
are defined on XHIST Bulk Data
Entry with TYPE =
GRID and
ENTRY=DEF
simultaneously. The force-deflection curve can be cross
plotted with the grid displacements and corresponding
rigid body forces in HyperGraph.
- NO (Default)
- Output of the force-deflection curve is not requested
and the internal rigid bodies are not generated.
