PARAM, GPSLOC
Bulk Data Entry Controls where the grid point stresses are calculated for output to the .mnf file.
| Parameter | Values | Description |
| GPSLOC | <Z1, Z2 and MID> | The highest stresses are
at the bottom (Z1) or top (Z2)
surface of the shell. For pure bending, they have the same
magnitude. GPSLOC is used to specify
the location of the calculation of the grid point stresses. They
can be calculated at:
