PARAM, REFPNT
Bulk Data Entry The reference point for Inertia Relief of the model.
Parameter | Values | Description |
REFPNT | <GEOM, CG> |
- If Center of Gravity of the model is not unique in all directions due to the scalar masses in the model, then the run will error out.
