This parameter is used to
specify the speed of sound used in the wave number and the complex
particle velocity vector calculations, as shown below (refer to
Radiated Sound Output Analysis in the
User Guide for further information): Wave
Number
The wave number
is defined as:
Where,
- Speed of sound defined by PARAM,
SPLC
- Frequency of the sound wave in the medium
Complex Particle Velocity Vector
The complex
particle velocity vector is defined for each frequency
as:
Where,
- pj(f)
- Complex acoustic pressure due to source grid
at the microphone
location.
- Unit vector from the source grid
to the microphone
grid.
- Density of the acoustic medium defined by
PARAM,
SPLRHO.
SPLC.
- Wave number defined above under Wave Number.
- Distance from the acoustic source grid
on the panel to the
microphone grid.
- Square root of -1.
