PARAM, PNLSIZ
Bulk Data Entry Increases the starting size of panel to the specified value.
| Parameter | Values | Description |
| PNLSIZ | < Integer > 0 > | Increases the starting
size of panel to the specified value. A larger panel size helps
stabilize the factorization of an indefinite stiffness matrix. Use this parameter when the job fails with Error 802. The default panel size (without using this parameter) is internally determined based on the model. |
