PARAM, ENFMETH
Bulk Data Entry Used to control the calculation of enforced displacement vectors in a Modal Frequency Response (MFREQ) analysis.
Parameter | Values | Description |
ENFMETH | <REL, ABS, or TOTAL> |
- ABS/TOTAL and REL should provide almost similar results when the dynamic matrices are symmetric.
- However, ABS/TOTAL is computationally efficient because it avoids calculation of static displacement vectors from SPCD degrees of freedom. ABS/TOTAL is very effective in dealing with asymmetric matrices (K2PP, M2PP, B2PP).
- For more details, refer to Frequency Response Analysis in the User Guide.
