PARAM, MAXDAMP
Bulk Data Entry Identifies the maximum number of residual vectors to be calculated.
| Parameter | Values | Description |
| MAXDAMP | <Integer> Default = 400 |
number of viscous residual vectors that are to be calculated. If
MAXDAMP is exceeded, a WARNING message is
issued and no viscous residual vectors are calculated. Solution times can be greatly extended due to the calculation of large numbers of viscous residual vectors, if this is not intended by the user. |
