PARAM, ENFMOTN
Bulk Data Entry Switch between relative and absolute displacement output in Modal Frequency Response Analysis with enforced motion.
| Parameter | Values | Description |
| ENFMOTN | <ABS, TOTAL, or REL> |
View new features for OptiStruct 2021.2.
OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
Discover OptiStruct functionality with interactive tutorials.
This manual provides detailed information regarding the features, functionality, and simulation methods available in OptiStruct.
This manual provides a detailed list and usage information regarding input entries, output entries, and parameters available in OptiStruct.
The input file in OptiStruct is composed of three distinct sections.
The following guidelines apply to all entries in the I/O Options and Subcase Information sections.
The following guidelines apply to all entries in the Bulk Data Entry section.
The Data Selectors table is available in an Excel spreadsheet.
Supported types of optimization for various analysis sequences are outlined.
Descriptions for individual I/O Option Entries can be accessed by selecting from the links for each entry, listed below in groups according to their purpose and alphabetically on the I/O Options section page.
Descriptions for individual Subcase Information Entries can be accessed by selecting from the links for each entry, listed below in groups according to their purpose and alphabetically on the Subcase Information Section page.
Guidelines for using Bulk Data Entries are listed in Bulk Data Guidelines.
Alphabetical listing of the I/O Options Entries.
Alphabetical listing of the Subcase Information Entries.
Alphabetical listing of the Bulk Data Entries.
Bulk Data Entry Defines acceleration loads to all grids in the model. These loads can either be constant or vary in a particular direction over sections of the model.
Bulk Data Entry Defines static acceleration loads at specific GRID points in the model.
Bulk Data Entry Defines static acceleration loads at a specific SET of GRID points in the model. Additionally, scale factors for varying direction acceleration loads can be defined using tabular data.
Bulk Data Entry Defines accelerometer for geometric nonlinear analysis.
Bulk Data Entry Defines model parameters for the fluid-structure interface.
Bulk Data Entry Defines acoustic source as a function of power versus frequency.
Bulk Data Entry Defines a component for use in monitoring point definition or external splines.
Bulk Data Entry Defines real numbers for Aeroelastic Analysis.
Bulk Data Entry Defines relationships between on among AESTAT and AESURF entries.
Bulk Data Entry Defines a list of aerodynamic box IDs.
Bulk Data Entry Defines basic parameters for dynamic aeroelasticity.
Bulk Data Entry Defines basic parameters for static aeroelasticity.
Bulk Data Entry Specifies rigid body motions to be used as trim variables in static aeroelasticity.
Bulk Data Entry Specifies an aerodynamic control surface as a member of the set of aerodynamic extra points. The forces associated with this controller will be derived from rigid rotation of the aerodynamic model about the hinge line(s).
Bulk Data Entry Defines the boundary degrees-of-freedom of a superelement assembly for matrix reduction.
Bulk Data Entry Corrects the acceleration record to avoid displacement shift.
Bulk Data Entry Indicates the beginning of data that is used to describe a specific entity (or entities) for inclusion in a model. The BEGIN entry is used in conjunction with the END entry to define the data required for a specific entity.
Bulk Data Entry Defines the blank holder force in a one-step stamping simulation.
Bulk Data Entry Defines quad or tria faces that are in turn used to define a barrier to limit the total deformation for free-shape design regions.
Bulk Data Entry Defines the degrees-of-freedom to be fixed during DMIG generation using CMSMETH card.
Bulk Data Entry Defines the fixed (B-set) degrees-of-freedom to be fixed during DMIG generation using CMSMETH card.
Bulk Data Entry Defines the free (C-set) degrees-of-freedom to be fixed during DMIG generation using CMSMETH card.
Bulk Data Entry Defines the surface, coordinate system, and parameters required to request Bore Deformation output for Static Analysis Subcases.
Bulk Data Entry Boundary Degrees-of-Freedom of a Superelement Assembly.
Bulk Data Entry Fixed Boundary Degrees-of-Freedom of a Superelement Assembly.
Bulk Data Entry Defines the frequency-dependent fluid acoustic absorber element in coupled fluid-structural analysis.
Bulk Data Entry Defines an Acoustic Infinite Element with a triangular base.
Bulk Data Entry Defines an Acoustic Infinite Element with a quadrilateral base.
Bulk Data Entry Defines an interface for forced convection heat transfer using CAFLUID.
Bulk Data Entry Defines an aerodynamic macro element (panel) in terms of two leading edge locations and side chords. This is used for Vortex Lattice Method (VLM) and Doublet Lattice Method (DLM) in subsonic aeroelastic analysis.
Bulk Data Entry Defines a 1D element that can conduct heat and transmit fluid between its two primary nodes.
Bulk Data Entry Defines a simple beam element (BAR) of the structural model.
Bulk Data Entry Defines a beam element (BEAM) of the structural model.
Bulk Data Entry Defines a generalized spring-damper structural element.
Bulk Data Entry Defines a one-dimensional spring-damper structural element.
Bulk Data Entry Defines a scalar damper element.
Bulk Data Entry Defines a scalar damper element without reference to a property entry.
Bulk Data Entry Defines a scalar damper element that is connected only to scalar points.
Bulk Data Entry Defines a scalar damper element that is connected only to scalar points and is without reference to a material or property entry.
Bulk Data Entry Defines a current density on the face of solid elements (HEXA, PENTA, TETRA, PYRA) or on the side of shell elements (TRIA3, TRIA6, QUAD4, QUAD8), in Electrical analysis.
Bulk Data Entry Can be used in the component dynamic synthesis method for generating component dynamic matrices at each loading frequency.
Bulk Data Entry Defines a scalar spring element of the structural model.
Bulk Data Entry Defines a scalar spring element of the structural model without reference to a property entry.
Bulk Data Entry Defines a scalar spring element of the structural model without reference to a property entry. The corresponding properties on this entry are not affected by translational and rotational stiffness limits specified using PARAM,ELASSTIF.
Bulk Data Entry Defines a scalar spring element that connects only to scalar points.
Bulk Data Entry Defines a scalar spring element that is connected only to scalar points without reference to a property entry.
Bulk Data Entry Defines a scalar spring element that is connected only to scalar points without reference to a property entry. The corresponding properties on this entry are not affected by translational and rotational stiffness limits specified using PARAM,ELASSTIF.
Bulk Data Entry Defines a unit cell comprised of lattice entities which can be used for space filling via the DLATTICE entry.
Bulk Data Entry Define a fastener with material orientation connecting two shell surfaces.
Bulk Data Entry Defines a gap or friction element.
Bulk Data Entry Defines a node-to-obstacle gap element. The obstacle may be an element face or a patch of nodes.
Bulk Data Entry Defines the connections of the GASK6 solid gasket element.
Bulk Data Entry Defines the connections of the GASK8 solid gasket element.
Bulk Data Entry Defines the connections of the GASK12 solid gasket element.
Bulk Data Entry Defines the connections of the GASK16 solid gasket element.
Bulk Data Entry Defines the acoustic absorber element in coupled fluid-structural analysis.
Bulk Data Entry Defines a surface element for application of thermal boundary condition.
Bulk Data Entry Defines the connections of the HEXA solid element.
Bulk Data Entry Defines the connections of the cohesive element.
Bulk Data Entry Defines parameters for clearance and threaded bolts geometry.
Bulk Data Entry Defines a scalar mass element.
Bulk Data Entry Defines a scalar mass element without reference to a property entry.
Bulk Data Entry Defines a scalar mass element that is connected only to scalar points.
Bulk Data Entry Defines a scalar mass element that is connected only to scalar points, without reference to a property entry.
Bulk Data Entry Defines a beam element for multibody dynamics solution sequence without reference to a property entry.
Bulk Data Entry Defines a beam element for multibody dynamic solution sequence without reference to a property entry based on markers.
Bulk Data Entry Defines a bushing element without reference to a property entry.
Bulk Data Entry Defines a bushing element without reference to a property entry based on markers.
Bulk Data Entry Defines the CMS (Component Mode Synthesis) method, frequency upper limit, number of modes, and starting SPOINT ID to be used in a CMS solution.
Bulk Data Entry Defines a spring damper element without reference to a property entry for multibody solution sequence.
Bulk Data Entry Defines a spring damper element without reference to a property entry for multibody solution sequence based on marker.
Bulk Data Entry Defines parameters for contact (S2S and N2S) interference.
Bulk Data Entry Defines parameters for stabilization control of contact (S2S and N2S) and gap elements (CGAP/CGAPG). This entry is supported with nonlinear static and nonlinear transient analysis types for both small and large displacement cases.
Bulk Data Entry Defines a 6x6 mass matrix at a geometric grid point.
Bulk Data Entry Defines a concentrated mass at a grid point of the structural model.
Bulk Data Entry Define equivalence for degrees of freedom of grid points of two sections of the same model (Format 2) or different parts in a Parts and Instances Model (Format 1) within a specified tolerance.
Bulk Data Entry Defines a rod element without reference to a property entry.
Bulk Data Entry Defines a contact interface.
Bulk Data Entry Defines the default properties of all contacts and sets parameters that affect all contacts.
Bulk Data Entry Defines an edge to edge or line to line contact interface.
Bulk Data Entry Defines a free convection boundary condition for heat transfer analysis through connection to a surface element (CHBDYE card).
Bulk Data Entry Defines a cylindrical coordinate system using three grid points. The first point is the origin, the second lies on the Z-axis, and the third lies in the X-Z plane.
Bulk Data Entry Defines a rectangular coordinate system using three grid points. The first point is the origin, the second lies on the Z-axis, and the third lies in the X-Z plane.
Bulk Data Entry Defines a spherical coordinate system using three grid points. The first point is the origin, the second lies on the Z-axis, and the third lies in the X-Z plane.
Bulk Data Entry Defines a cylindrical coordinate system using three grid points specified with respect to a reference coordinate system.
Bulk Data Entry Defines a rectangular coordinate system by using three grid points.
Bulk Data Entry Defines a spherical coordinate system three grid points.
Bulk Data Entry Defines a rectangular coordinate system using three grid points. The first point is the origin, the second lies on the X-axis, and the third lies in the X-Y plane.
Bulk Data Entry Defines a rectangular coordinate system using three grid points specified with respect to the basic coordinate system.
Bulk Data Entry Defines a coupler connecting two or three joints.
Bulk Data Entry Defines the connections of the CPENTA element.
Bulk Data Entry Defines the connections of the PYRA solid element.
Bulk Data Entry Defines an axisymmetric quadrilateral cross-section ring element.
Bulk Data Entry Defines a plane strain quadrilateral element in x-z or x-y plane.
Bulk Data Entry Defines a quadrilateral plate element (QUAD4) of the structural model. This element uses a 6 degree-of-freedom per node formulation.
Bulk Data Entry Defines a curved quadrilateral shell element with eight grid points.
Bulk Data Entry Equivalent to CQUAD4. Unlike other Nastran codes, a 6 degree-of-freedom per node formulation is used for all shell elements.
Bulk Data Entry Defines a tension-compression-torsion element (ROD) of the structural model.
Bulk Data Entry Defines a seam weld connecting two shell surfaces.
Bulk Data Entry Defines a two-noded element used in the definition of arbitrary beam cross-sections.
Bulk Data Entry Defines a 1st order, three-noded element used in the definition of arbitrary beam cross-sections.
Bulk Data Entry Defines a 1st order, four-noded element used in the definition of arbitrary beam cross-sections.
Bulk Data Entry Defines a planar, 2nd order, six-noded element used in the definition of arbitrary beam cross-sections.
Bulk Data Entry Defines a planar 2nd order, eight-noded element used in the definition of arbitrary beam cross-sections.
Bulk Data Entry Defines a shear panel element.
Bulk Data Entry Defines the Exterior grid points for One-Step Superelement Analysis.
Bulk Data Entry Defines an axisymmetric triangular cross-section ring element.
Bulk Data Entry Defines the connections of the CTETRA element.
Bulk Data Entry Defines a plane strain triangular element in x-z or x-y plane.
Bulk Data Entry Defines a triangular plate element (TRIA3) of the structural model. This element uses a 6 degree-of-freedom per node formulation.
Bulk Data Entry Defines a curved triangular shell element with six grid points.
Bulk Data Entry CTRIAR entry is equivalent to CTRIA3. Unlike other Nastran codes, a 6 degrees-of-freedom per node formulation is used for all shell elements.
Bulk Data Entry Defines a tension-compression-torsion element (TUBE) of the structural model.
Bulk Data Entry Defines a static point current at a grid or a set of grids, by specifying a vector, in Electrical analysis.
Bulk Data Entry Defines a viscous damper element.
Bulk Data Entry Defines a weld or fastener connecting two surface patches or points.
Bulk Data Entry Used to list the grids that lie on the axis of symmetry, in cyclic symmetry analysis.
Bulk Data Entry Defines points on one of the boundaries that connect to adjacent segments in cyclic symmetry analysis.
Bulk Data Entry Specifies the number of segments, in a cyclic symmetry analysis.
Bulk Data Entry Defines scale (area) factors for dynamic loads. DAREA is used in conjunction with RLOAD1, RLOAD2, TLOAD1, and TLOAD2 entries.
Bulk Data Entry Defines manufacturing constraints for composite sizing optimization.
Bulk Data Entry Creates a combination of several DCONSTR sets that can be referenced by a subcase.
Bulk Data Entry Defines design constraint upper and lower bounds where response is defined by DRESP1, DRESP2, and DRESP3 cards.
Bulk Data Entry Define real, discrete design variable values for discrete variable optimization or to define relative rotor spin rates in rotor dynamics.
Bulk Data Entry Defines enforced axial deformation for one-dimensional elements for use in statics problems.
Bulk Data Entry Defines the time delay term in the equations of the dynamic loading function. DELAY is used in conjunction with RLOAD1, RLOAD2, TLOAD1, and TLOAD2 entries.
Bulk Data Entry Specifies one or more equations for use in optimization.
Bulk Data Entry Defines a design variable.
Bulk Data Entry Defines an override for design variable settings.
Bulk Data Entry Defines input parameters required for the Global Search Option (GSO).
Bulk Data Entry Defines a link between a DIM# field on a PBARL or PBEAML property and either the thickness on a PSEC definition or the y or z coordinate on a GRIDS definition; it is used in the definition of arbitrary beam cross-sections.
Bulk Data Entry Specifies the number of Divergence pressures and Mach numbers for a static aeroelastic divergence analysis.
Bulk Data Entry Defines parameters for filling a space with lattice-based unit cells. The presence of this entry also activates the creation of unit cells to fill the target volume.
Bulk Data Entry Defines a link between one design variable and one or more other design variables.
Bulk Data Entry Defines a link of one design variable to one or more other design variables defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and the constants defined on the DTABLE card.
Bulk Data Entry Defines a dynamic loading condition for frequency response problems as a linear combination of load sets defined via RLOAD1 and RLOAD2 entries, or for transient problems as a linear combination of load sets defined via TLOAD1 and TLOAD2 entries, or acoustic source ACSRCE entries.
Bulk Data Entry Defines the damage evolution.
Bulk Data Entry Defines the damage initiation criteria.
Bulk Data Entry Defines direct input matrices related to grid points. The matrix is defined by a single header entry and one or more column entries. A column entry is required for each column with non-zero elements.
Bulk Data Entry Defines changes in the contents of a super element from H3DDMIG input.
Bulk Data Entry Controls rotation and other specifications for a matrix entered using DMIG entry.
Bulk Data Entry Defines a response and its reference values for a minmax (maxmin) optimization problem.
Bulk Data Entry Defines design optimization parameters by overriding the defaults.
Bulk Data Entry Defines the phase lead term in the equation of the dynamic loading function. DPHASE is used in conjunction with RLOAD1 and RLOAD2 entries.
Bulk Data Entry Defines the draping data for plies used in ply-based composite definition.
Bulk Data Entry Creates a combination of several DREPORT sets that can be referenced by a subcase.
Bulk Data Entry Used in the Bulk Data section to report responses, defined by DRESP1, DRESP2 and DRESP3 cards, to the output file, which are not constrained or used as the objective function, as defined by the optimization problem.
Bulk Data Entry A response or a set of responses that are the result of a design analysis iteration. These responses can be used as a design objective or as design constraints.
Bulk Data Entry When a desired response is not directly available from OptiStruct, it may be calculated using DRESP2.
Bulk Data Entry The DRESP3 card identifies the external function to be called and defines the parameters to be transferred to that function.
Bulk Data Entry Defines design response screening data.
Bulk Data Entry Defines parameters for classic and grid-based free-shape design variables.
Bulk Data Entry Defines parameters for the generation of composite shuffling design variables.
Bulk Data Entry Defines parameters for the generation of free-size design variables.
Bulk Data Entry Defines responses and their target values for a system identification problem.
Bulk Data Entry List of constants to be used in functions defined by DEQATN.
Bulk Data Entry Correlates spectra lines specified on TABLED1 entries with damping values.
Bulk Data Entry Defines units for multibody, component mode synthesis (flexible-body preparation), and Explicit Dynamic Analysis (EXPDYN) sequences.
Bulk Data Entry Defines parameters for the generation of topography design variables.
Bulk Data Entry Defines parameters for the generation of topology design variables.
Bulk Data Entry Relates Design Variables to Analysis Model Element Properties
Bulk Data Entry Relates design variables to an analysis model element property using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and constants defined on a DTABLE card.
Bulk Data Entry Defines the relationship between a design variable and a grid point location.
Bulk Data Entry Linearly relates a design variable to an analysis model element.
Bulk Data Entry Relates a design variable to an analysis model loading using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and the constants defined on the DTABLE card.
Bulk Data Entry Linearly relates a design variable to properties of an MBD entity using the equation:
Bulk Data Entry Relates a design variable to properties of MBD entities using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and the constants defined on the DTABLE card.
Bulk Data Entry Linearly relates a design variable to an analysis model material property using the equation:
Bulk Data Entry Relates design variables to an analysis model material property using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and constants defined on a DTABLE card.
Bulk Data Entry Relates Design Variables to Analysis Model Properties
Bulk Data Entry Relates a design variable to an analysis model property using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and the constants defined on the DTABLE card.
Bulk Data Entry Defines geometry and restraining force per unit length for an edge blank holder in a one-step stamping simulation.
Bulk Data Entry Defines location and restraining force per unit length for a draw bead in a one-step stamping simulation.
Bulk Data Entry Defines data required to perform complex eigenvalue analysis.
Bulk Data Entry Defines the data required to perform real eigenvalue analysis with the Automated Multi-Level Sub-structuring technique.
Bulk Data Entry Defines data required to perform eigenvalue extraction using the Lapack-based dense solver.
Bulk Data Entry Defines data required to perform real eigenvalue analysis (vibration or buckling) with the Lanczos Method.
Bulk Data Entry Used to assign material ID to elements.
Bulk Data Entry Used to assign property ID to elements in DMIG.
Bulk Data Entry Resets the default values of the warning and error bound limits for element quality check.
Bulk Data Entry Specifies damp shell elements for a fluid volume. ELIST entries are referenced by the MFLUID entry.
Bulk Data Entry The END Bulk Data Entry indicates the end of data that is used to describe a specific entity (or entities) for inclusion in a model. The END entry is used in conjunction with the BEGIN entry to define the data required for a specific entity.
Bulk Data Entry Defines one or more sets of elements as panels for equivalent radiated power output for a frequency response analysis.
Bulk Data Entry Defines a combined time step selection set as a union of selected time steps defined via ESLTIME entries for Geometric Nonlinear ESLM optimization or a Multibody Dynamics ESLM optimization.
Bulk Data Entry Defines time step selection control for geometric nonlinear response ESL Optimization and Multibody dynamics ESLM optimization.
Bulk Data Entry Defines boundary connections for an external superelement.
Bulk Data Entry Defines elements or grids, and associated fatigue properties, for consideration in a fatigue analysis.
Bulk Data Entry Defines loading events for fatigue analysis.
Bulk Data Entry Defines fatigue loading parameters.
Bulk Data Entry Specifies the corresponding quantities (Ti) versus SN curve table ID’s via TABLEXN entries (TIDi).
Bulk Data Entry Used to define parameters required for a Fatigue Analysis.
Bulk Data Entry Defines the solder joint for consideration in solder fatigue analysis.
Bulk Data Entry Used to define parameters and property identification data for Seam Weld Fatigue Analysis.
Bulk Data Entry Defines a loading sequence for a Fatigue Analysis.
Bulk Data Entry Defines a forming limit curve as a table of minor and major strain values in a one-step stamping simulation.
Bulk Data Entry Used to specify the aerodynamic factors in aerodynamic flutter analysis.
Bulk Data Entry Defines parameters for the calculation follower loads in large displacement nonlinear analysis.
Bulk Data Entry Used to specify the parameters required for aerodynamic flutter analysis.
Bulk Data Entry Defines a static force at a grid point or a SET of grid points by specifying a vector.
Bulk Data Entry Used to define a static force by specification of a value and two grid points that determine the direction.
Bulk Data Entry Used to define a static force by specification of a value and four grid points that determine the direction.
Bulk Data Entry Defines a set of frequencies to be used in the solution of frequency response problems.
Bulk Data Entry Defines a set of frequencies to be used in the solution of frequency response problems by specification of a starting frequency, frequency increment, and the number of increments desired.
Bulk Data Entry Defines a set of frequencies to be used in the solution of frequency response problems by specification of a starting frequency, final frequency, and the number of logarithmic increments desired.
Bulk Data Entry Defines a set of frequencies for the modal method of frequency response analysis by specifying the number of frequencies between modal frequencies.
Bulk Data Entry Defines a set of frequencies for the modal method of frequency response analysis by specifying the amount of "spread" around each modal frequency and the number of equally spaced frequencies within the spread.
Bulk Data Entry Defines a set of frequencies for the modal method of frequency response analysis by specification of a frequency range and fractions of the natural frequencies within that range.
Bulk Data Entry Defines the settings for Fluid-Structure Interaction Analysis with AcuSolve.
Bulk Data Entry Defines parameters that control connectivity and configuration checks for gap elements (CGAP and CGAPG). Most of these parameters also affect contact elements that are automatically created on CONTACT interfaces - see individual descriptions for details.
Bulk Data Entry Defines the stiffness, flexibility, mass, viscous damping, or structural damping of a general element connected to an arbitrary number of grids.
Bulk Data Entry Defines equivalence for all degrees of freedom of grid points of two different subsets of without any requirement that these two subsets are closely located to one another.
Bulk Data Entry Defines the gravity vectors for use in determining gravity loading for the static structural model. It can also be used to define the EXCITEID field (Amplitude "A") of dynamic loads in RLOAD1, RLOAD2, TLOAD1, TLOAD2 and NLOAD1 Bulk Data Entries for dynamic solution sequences.
Bulk Data Entry Defines default options for fields 3, 7, and 8 of all GRID entries.
Bulk Data Entry Defines the location of a geometric grid point of the structural model, the directions of its displacement, and its permanent single-point constraints.
Bulk Data Entry Defines a grid point on the y-z plane, using cartesian coordinates, for use in the definition of arbitrary beam cross-sections.
Bulk Data Entry Defines a ground body out of a list of finite element properties, elements, and grid points.
Bulk Data Entry Defines hourglass control parameters to reduce spurious zero-energy modes in elements with reduced integration.
Bulk Data Entry Defines the application of modal damping to the residual structure in a Direct Transient or Frequency Response analysis.
Bulk Data Entry Define the initial geometric imperfection at the beginning of a nonlinear analysis.
Bulk Data Entry This Bulk Data card is identical to the I/O Options Entry, INCLUDE.
Bulk Data Entry Defines initial stress values and settings for elements in nonlinear analysis.
Bulk Data Entry Defines the Inlet velocity for Darcy Flow Analysis.
Bulk Data Entry The INSTNCE Bulk Data Entry can be used to define the location of a part in the global structure. Each INSTNCE entry should reference a unique part name.
Bulk Data Entry Defines initial stress condition for nonlinear quasi-static analysis as a union of INISTRS entries.
Bulk Data Entry Defines initial velocity in a multibody situation.
Bulk Data Entry Defines initial velocity of a joint in a multibody situation.
Bulk Data Entry Defines a joint for Multibody Dynamics.
Bulk Data Entry Defines a joint connection between two grids.
Bulk Data Entry Defines a joint using two grids which have a marker card associated with them. Joints are only valid in a multibody solution sequence.
Bulk Data Entry Defines the parameters available for Lattice Optimization Control.
Bulk Data Entry Definition of a line.
Bulk Data Entry The LOAD is equivalent to the LOADADD.
Bulk Data Entry Defines a static load as a linear combination of load sets defined via FORCE, MOMENT, FORCE1, MOMENT1, PLOAD, PLOAD1, PLOAD2, PLOAD4, RFORCE, DAREA, ACCEL, ACCEL1, ACCEL2, GRAV and LOADADD entries.
Bulk Data Entry Used to define the harmonic coefficients of loading, in cyclic symmetry analysis.
Bulk Data Entry Used to define the loading, in cyclic symmetry analysis.
Bulk Data Entry Defines loading for joint connector JOINTG Bulk Data Entry.
Bulk Data Entry The LOCATE Bulk Data Entry can be used to define the location of a part in the global structure. Each LOCATE entry should reference a unique part name. LOCATE Bulk Data Entries are activated in each subcase by the LOCATE Subcase Entry.
Bulk Data Entry Used to map results to the model (OptiStruct) from other external result files.
Bulk Data Entry Define a marker by associating a grid and a coordinate system.
Bulk Data Entry Defines the material properties for linear, temperature-independent, and isotropic materials.
Bulk Data Entry Defines constant electrical material properties for conductivity, Joule heat fraction and reference temperature in electrical analysis.
Bulk Data Entry Defines the material properties for linear, temperature-independent, and anisotropic materials for two-dimensional elements.
Bulk Data Entry Defines the electrical material properties for anisotropic materials in electrical analysis.
Bulk Data Entry Defines the material properties for linear, temperature-independent, and orthotropic materials used by the CTAXI, CTRIAX6, and CQAXI axisymmetric elements, and CTPSTN and CQPSTN plane strain elements.
Bulk Data Entry Defines constant thermal material properties for conductivity, density, and heat generation.
Bulk Data Entry Defines the thermal material properties for anisotropic materials.
Bulk Data Entry Defines the material properties for linear temperature-independent orthotropic material for two-dimensional elements.
Bulk Data Entry Defines the material properties for linear, temperature-independent, and anisotropic materials for solid elements.
Bulk Data Entry Defines the material properties for linear, temperature-independent, and orthotropic materials for solid elements in terms of engineering constants.
Bulk Data Entry Defines material properties for fluid elements in coupled fluid-structural analysis.
Bulk Data Entry Defines material properties and failure model parameters for Failure criteria calculations.
Bulk Data Entry Defines material properties for fatigue analysis.
Bulk Data Entry Specifies frequency-dependent material properties on MAT1 entry fields via TABLEDi entries.
Bulk Data Entry Specifies frequency-dependent material properties on MAT2 entry fields via TABLEDi entries.
Bulk Data Entry Specifies frequency-dependent material properties on MAT3 entry fields via TABLEDi entries.
Bulk Data Entry Specifies frequency-dependent material properties on MAT8 entry fields via TABLEDi entries.
Bulk Data Entry Specifies frequency-dependent material properties on MAT9 entry fields via TABLEDi entries.
Bulk Data Entry Specifies frequency-dependent material properties on MAT10 entry fields via TABLEDi entries.
Bulk Data Entry Defines material properties for frequency-dependent viscoelastic materials.
Bulk Data Entry Defines material properties for nonlinear hyperelastic materials. The Polynomial form is available and various material types topics/solvers/os/mathe_bulk_r.html#mathe_bulk_r__mathe_bulk_r_fn_jgc_4dt_b1b can be defined by specifying the corresponding coefficients.
Bulk Data Entry Defines the material properties in a one-step stamping simulation.
Bulk Data Entry Defines material properties and parameters through an interface to Altair Multiscale Designer™ allowing you to include a much wider range of different material models.
Bulk Data Entry Defines the material properties for poro-elastic materials.
Bulk Data Entry Specifies stress-dependent and temperature-dependent material properties for use in applications involving nonlinear materials.
Bulk Data Entry Specifies temperature-dependent material properties on MAT1 entry fields via TABLEMi or TABLEG entry.
Bulk Data Entry Defines temperature-dependent material properties for the corresponding MAT1EC Bulk Data Entry fields via TABLEMi or TABLEG entries.
Bulk Data Entry Specifies temperature-dependent material properties on MAT2 entry fields via TABLEMi or TABLEG entry.
Bulk Data Entry Defines temperature-dependent material properties for the corresponding MAT2EC Bulk Data Entry fields via TABLEMi or TABLEG entries.
Bulk Data Entry Specifies temperature-dependent material properties on MAT3 entry fields via TABLEMi or TABLEG entry.
Bulk Data Entry Defines temperature-dependent material properties for the corresponding MAT4 Bulk Data Entry fields via TABLEMi or TABLEG entry.
Bulk Data Entry Specifies temperature-dependent material properties on MAT8 entry fields via TABLEMi or TABLEG entry.
Bulk Data Entry Specifies temperature-dependent material properties on MAT9 entry fields via TABLEMk or TABLEG entry.
Bulk Data Entry Specifies temperature-dependent material properties on MAT9OR entry fields via TABLEMk or TABLEG entry.
Bulk Data Entry Defines material properties for temperature-dependent nonlinear hyperelastic materials.
Bulk Data Entry Defines temperature-dependent material properties for the corresponding MATVP Bulk Data Entry fields via TABLEMi or TABLEG entry.
Bulk Data Entry Defines thermal material properties and parameters for user-defined thermal material.
Bulk Data Entry Defines material properties and parameters for user-defined structural material.
Bulk Data Entry Defines material properties for nonlinear viscoelastic materials.
Bulk Data Entry Defines material properties for nonlinear creep materials.
Bulk Data Entry Defines void material for geometric nonlinear analysis.
Bulk Data Entry Defines additional material properties for Johnson-Cooke elastic-plastic material for geometric nonlinear analysis. This is an elasto-plastic law with strain rate and temperature effects.
Bulk Data Entry Defines rigid material for geometric nonlinear analysis.
Bulk Data Entry Defines additional material properties for Rock-Concrete material for geometric nonlinear analysis.
Bulk Data Entry Defines an elasto-plastic orthotropic material with Tsai-Wu and CRASURVT yield criteria for composite shell materials.
Bulk Data Entry Defines additional material properties for elastic-plastic brittle material for geometric nonlinear analysis.
Bulk Data Entry Defines additional material properties for Honeycomb material for geometric nonlinear analysis. This law is only applicable to solid elements.
Bulk Data Entry Defines additional material properties for visco-elastic plastic foam material for geometric nonlinear analysis.
Bulk Data Entry Defines additional material properties for piece-wise linear elastic-plastic material for geometric nonlinear analysis.
Bulk Data Entry Defines additional material properties for viscoelastic foam tabulated material (tabulated form) for geometric nonlinear analysis.
Bulk Data Entry Defines additional material properties for Ogden, Mooney-Rivlin material for geometric nonlinear analysis. This material is used to model rubber, polymers, and elastomers.
Bulk Data Entry Defines additional material properties for Hill Orthotropic material for geometric nonlinear analysis. This law is only applicable to two-dimensional elements.
Bulk Data Entry Defines additional material properties for Cowper-Symonds elastic-plastic material for geometric nonlinear analysis.
Bulk Data Entry Defines additional material properties for piece-wise nonlinear elastic-plastic material for geometric nonlinear analysis.
Bulk Data Entry Defines additional material properties for Hyper-visco-elastic material for geometric nonlinear analysis. This material is used to model rubber, polymers, and elastomers. This material is compatible with solid and shell elements.
Bulk Data Entry Defines additional material properties for tabulated strain rate dependent elastic-plastic material for geometric nonlinear analysis.
Bulk Data Entry Defines additional material properties for tabulated visco-elastic foam material for explicit dynamic analysis.
Bulk Data Entry Defines additional material properties for Ogden material for geometric nonlinear analysis. This material is used to model rubber, polymers, and elastomers.
Bulk Data Entry Defines the entity/set that needs to be activated in the multibody system for the subsequent simulation.
Bulk Data Entry Defines a Multibody Contact between a set of nodes and a deformable surface.
Bulk Data Entry Defines a Multibody contact between rigid bodies.
Bulk Data Entry Specifies the data used to define a curve.
Bulk Data Entry Defines a Curve to Curve Constraint.
Bulk Data Entry Defines an ordered list of grids as a Multibody Deformable Curve.
Bulk Data Entry Defines the entity/set that needs to be deactivated in the multibody system for the subsequent simulation.
Bulk Data Entry Defines a multibody deformable surface.
Bulk Data Entry Defines a constant force at a grid point by specifying a vector.
Bulk Data Entry Defines a curve force at a grid point by specifying a vector.
Bulk Data Entry Defines an expression force at a grid point by specifying a vector.
Bulk Data Entry Defines the parameters for a multibody system linear analysis.
Bulk Data Entry Defines a constant moment at a grid point by specifying a vector.
Bulk Data Entry Defines a curve moment at a grid point by specifying a vector.
Bulk Data Entry Defines an expression moment at a grid point by specifying a vector.
Bulk Data Entry Defines a Multibody Parametric Curve using node sets.
Bulk Data Entry Defines a Point to Parametric Curve Constraint.
Bulk Data Entry Defines a Point to Deformable Curve Constraint.
Bulk Data Entry Defines a Point to Deformable Surface Constraint.
Bulk Data Entry Defines a multibody as a combination of request sets defined via MBREQE and MBREQM.
Bulk Data Entry Defines a multibody solver output request to output the results of a set of expressions.
Bulk Data Entry Defines a multibody solver output request to output displacement, velocity, acceleration, or force with respect to markers.
Bulk Data Entry Defines the simulation sequence for the multibody solver.
Bulk Data Entry Defines a constant scalar load on two grid points.
Bulk Data Entry Defines a curve scalar load on two grid points.
Bulk Data Entry Defines an expression scalar load on two grid points.
Bulk Data Entry Defines the parameters for a multibody simulation.
Bulk Data Entry Defines the simulation parameters for subsequent multibody simulation.
Bulk Data Entry Defines a constant scalar moment on two gird points along the specified vector.
Bulk Data Entry Defines a curve scalar moment on two grid points along the specified vector.
Bulk Data Entry Defines an expression scalar moment on two grid points along the specified vector.
Bulk Data Entry Defines a multibody solver variable which can be referred to by multiple expressions.
Bulk Data Entry Defining the material properties of cast iron material for use in applications involving nonlinear materials.
Bulk Data Entry Defines the material properties for potential-based cohesive material models.
Bulk Data Entry Defines the material properties for damage-based cohesive material models.
Bulk Data Entry METADATA indicates the beginning of metadata content that is to be passed to the OUTPUT2 (.op2 file).
Bulk Data Entry Defines the parameters and damp shell elements for a fluid volume.
Bulk Data Entry Defining the material properties for gasket-like materials.
Bulk Data Entry To input a table of Mach numbers (M) and reduced frequencies (K) for aerodynamic matrix calculation, in unsteady aerodynamic analysis.
Bulk Data Entry To input a table of Mach number (M) and reduced frequency (K) pairs for aerodynamic matrix calculation, in unsteady aerodynamic analysis.
Bulk Data Entry Defines a multibody as a linear combination of load sets defined via GRAV, MBFRC, MBFRCC, MBFRCE, MBMNT, MBMNTC, MBMNTE, MBSFRC, MBSFRCC, MBSFRCE, MBSMNT, MBSMNTC, and MBSMNTE.
Bulk Data Entry Defines parameters for removing and/or reactivating contact interfaces and/or elements.
Bulk Data Entry Options for displacement and energy results, based on eigenvectors from PFMODE modal participation.
Bulk Data Entry Defines a static moment at a grid point or a SET of grid points by specifying a vector.
Bulk Data Entry Defines a static moment by specification of a value and two grid points, which determines the direction.
Bulk Data Entry Defines a static moment by specification of a value and four grid points, which determines the direction.
Bulk Data Entry Defines an integrated load monitor point at a point (x,y,z) in a user-defined coordinate system. The integrated loads about this point over the associated loads will be computed and printed to the .monpnt file.
Bulk Data Entry Define an integrated load monitor point for specific elements and to output results for these elements.
Bulk Data Entry Sums select Grid Point Forces to a user chosen monitor point.
Bulk Data Entry Defines a multibody as a combination of motion sets defined via MOTNJ, MOTNJC, MOTNJE, MOTNG, MOTNGC, and MOTNGE.
Bulk Data Entry Defines a constant grid point motion.
Bulk Data Entry Defines a grid point motion versus time by specifying a curve.
Bulk Data Entry Defines a grid point motion through an expression.
Bulk Data Entry Defines a constant joint motion.
Bulk Data Entry Defines a joint motion versus time by specifying a curve.
Bulk Data Entry Defines a joint motion through an expression.
Bulk Data Entry Defines motion for joint connector JOINTG Bulk Data Entry.
Bulk Data Entry The MPC Bulk Data Entry defines a multipoint constraint equation of the form.
Bulk Data Entry Defines a multipoint constraint set as a union of multipoint constraint sets defined via MPC entries.
Bulk Data Entry Defines parameters for time-stepping and convergence criteria in Nonlinear Analysis.
Bulk Data Entry Defines parameters for energy variables printout for implicit nonlinear static, implicit nonlinear transient analyses, and explicit dynamic analysis.
Bulk Data Entry Defines the settings for runtime monitoring of nonlinear analysis.
Bulk Data Entry Defines a loading condition for nonlinear problems as a linear combination of load sets defined via NLOAD1.
Bulk Data Entry Defines a time-dependent load or enforced motion for use in explicit dynamic analysis.
Bulk Data Entry Defines incremental result output parameters for Nonlinear Implicit Analysis (static and transient) and Nonlinear Explicit Analysis.
Bulk Data Entry Defines parameters for Nonlinear Static Analysis, Nonlinear Direct Transient Analysis, and Heat Transfer Analysis solution control.
Bulk Data Entry Define the parameters for arc-length method to solve post-buckling problems in nonlinear static analysis.
Bulk Data Entry Controls the printing of certain information to the _nl.out file for nonlinear analysis.
Bulk Data Entry Defines a nonlinear radial (circular) gap for direct transient response analysis.
Bulk Data Entry Defines nonlinear transient forcing functions of the form.
Bulk Data Entry Defines non-structural material damping for a list of elements or properties.
Bulk Data Entry Defines non-structural material damping as the sum of the sets listed.
Bulk Data Entry Defines non-structural mass per unit Length, per unit Area, or per unit Volume for a list of elements or properties.
Bulk Data Entry Defines non-structural mass per unit area or per unit length for a list of elements or properties.
Bulk Data Entry Defines non-structural mass as the sum of the sets listed.
Bulk Data Entry Defines lumped non-structural mass for a list of elements or properties.
Bulk Data Entry Defines the properties of the fluid acoustic absorber element.
Bulk Data Entry Defines the properties of an acoustic absorber element.
Bulk Data Entry Defines the properties of Acoustic Infinite Elements.
Bulk Data Entry Defines properties for CAERO1 panels. This is used for Vortex Lattice Method (VLM) and Doublet Lattice Method (DLM) in subsonic aeroelastic analysis.
Bulk Data Entry Defines the properties of a 1D CAFLUID heat flow element.
Bulk Data Entry Defines up to four sets of grid points or elements as panels for panel participation output for a frequency response analysis of a coupled fluid-structural model.
Bulk Data Entry Defines a set of grid points and/or elements as generic panel.
Bulk Data Entry Defines values for parameters used during analysis and optimization.
List of parameters according to parameter type.
Bulk Data Entry Restores the ACMODL formulation used in version 12.0 and earlier for the Fluid-Structure Interface.
Bulk Data Entry To support output of the fluid-structure coupling matrix to the Punch (.pch) file as a matrix defined using DMIG data entry.
Bulk Data Entry Use external fluid-structure coupling matrix generated by AKUSMOD.
Bulk Data Entry This parameter is used to control the output from multiple failure theories to the H3D and .cstr files.
Bulk Data Entry Adds Rayleigh damping to viscous damping for structural mesh.
Bulk Data Entry Adds Rayleigh damping to viscous damping for fluid mesh.
Bulk Data Entry Use external AMLS eigenvalue solver.
Bulk Data Entry Used to determine singularities in the stiffness matrix for AMLS eigenvalue solver.
Bulk Data Entry Defines the amount of memory in Gigabytes to be used by the external AMLS eigenvalue solver.
Bulk Data Entry Used to define the number of CPUs to be used by the external AMLS eigenvalue solver.
Bulk Data Entry Constrain unconnected grids for AMLS eigenvalue solver.
Bulk Data Entry Controls the alternate method for the creation of CMS superelements using the AMSES eigensolver.
Bulk Data Entry Controls the activation of the enforced motion static solution in the AMSES solver in conjunction with the normal modes calculation.
Bulk Data Entry Indicates if the AMSES numerical mode for enforced motion based modal dynamic analysis with large mass method will be activated or not.
Bulk Data Entry Generates the fluid-structure coupling (area) matrix for use in the solution.
Bulk Data Entry Converts accelerations specified in units of gravity on the TRIM Bulk Data Entry to units of distance per time squared.
Bulk Data Entry Automatically convert dependent degrees-of-freedom of rigid elements to independent degrees-of-freedom.
Bulk Data Entry Automatically constrain degrees-of-freedom with no stiffness.
Bulk Data Entry Activate inertia relief and auto-support degree-of-freedom generation.
Bulk Data Entry Allows definition of a user-specified axis of symmetry, in cyclic symmetry analysis.
Bulk Data Entry Used to activate an alternate formulation for CBAR and CBEAM elements.
Bulk Data Entry Defines the maximum size in 8 byte words of the records of data written to the .op2 file.
Bulk Data Entry Issues a WARNING when the stiffness value for rotational components on the PBUSH entry exceeds the specified limit (BUSHRLMT).
Bulk Data Entry Specifies a value to replace large stiffness values (>1.0E+07) input in field K of the PBUSH Bulk Data Entry.
Bulk Data Entry Issues a WARNING when the stiffness value for translational components on the PBUSH entry exceeds the specified limit (BUSHTLMT).
Bulk Data Entry Generates files which contain the generated internal CAFLUID elements, along with the CONV entries and CHBDYE elements.
Bulk Data Entry Scale factor for direct input damping matrices.
Bulk Data Entry Controls the activation of MPC-based Fast Contact Analysis.
Bulk Data Entry Controls the printing of the final state of DMIG,CDSHUT for the constrained degrees of freedom at the gap interface to the PUNCH file for MPC-based Fast Contact Analysis.
Bulk Data Entry Controls the printing of violations during intermediate iterations in MPC-based Fast Contact Analysis to the .out file.
Bulk Data Entry Activates element quality checking.
Bulk Data Entry Activates material property checking.
Bulk Data Entry Specifies or excludes an element set from element quality check.
Bulk Data Entry Activates gap direction alignment checking.
Bulk Data Entry OptiStruct calculates the ratio of and prints a WARNING if the frequency interval may not be fine enough for accurate Fatigue Damage calculation.
Bulk Data Entry Scale factor for direct input stiffness matrices.
Bulk Data Entry Specifies factors for the stiffness matrix produced by GENEL cards.
Bulk Data Entry Scale factor for direct input mass matrices.
Bulk Data Entry Controls the inclusion of mass contribution from the mass matrix stored in the PUNCH DMIG or the H3D DMIG files for the generation of RFORCE and Gravity Loads.
Bulk Data Entry Allows flexible body generation when directional masses are defined in the input file.
Bulk Data Entry Consider shell offsets for flexbody generation.
Bulk Data Entry Defines the Corner Stress type for Fatigue analysis, if Corner Stress type is not requested, via the corresponding STRESS output request.
Bulk Data Entry Friction coefficient on curvatures for one-step stamping simulation.
Bulk Data Entry Results of homogenization of composite properties.
Bulk Data Entry Controls the transverse shear stress calculation for composite shells, (PCOMP, PCOMPP, PCOMPG) and continuum shells (PCOMPLS).
Bulk Data Entry Activates Contact-friendly elements. This is recommended when second order solids/gaskets are used with contact analysis in OptiStruct.
Bulk Data Entry Use coupled mass matrix approach for eigenvalue/dynamic analysis.
Bulk Data Entry Scale factor for direct input load matrices.
Bulk Data Entry Controls the printing of the “n” smallest element/nodal timesteps for Nonlinear Explicit Analysis.
Bulk Data Entry Use wall time based cost evaluation for Lanczos steps.
Bulk Data Entry Specifies how many decimal digits may be lost to cancellation in one operation during the eigensolution process.
Bulk Data Entry Flag for tangential stiffness of closed gaps (closed contact elements) in nonlinear preloaded linear analysis.
Bulk Data Entry Activates a correction to strain and stress calculation for second order shell elements (CQUAD8, CTRIA6) that considers strong curvature of the shell (relative to shell thickness).
Bulk Data Entry Identifies the number of groups into which the specified MPI processes (-np) are divided.
Bulk Data Entry Used to determine duplicate frequencies.
Bulk Data Entry Skip indefinite mass matrix check.
Bulk Data Entry Used to allow AMLS to handle disconnected parts. This can also be accomplished with PARAM, AMLSUCON.
Bulk Data Entry Used to control the displacements output for the fictitious grids of CWELD, CGAP, CFAST and CSEAM elements.
Bulk Data Entry Sets a threshold (minimum absolute value) for the printing of Design Sensitivities.
Bulk Data Entry Level of accuracy used in determining duplicate grids.
Bulk Data Entry This parameter is a switch for the type of Grid Point Stress calculation for mid-edge nodes in second order elements.
Bulk Data Entry Outputs modal participation factors and effective mass for normal modes analyses.
Bulk Data Entry Prints the inverse of the stiffness matrix created by static reduction to Fortran unit 3.
Bulk Data Entry Issues a WARNING when the stiffness value for rotational components on the CELAS2/CELAS4 or PELAS entry exceeds the specified limit (ELASRLMT).
Bulk Data Entry Specifies a value to replace large stiffness values (>1.0E+07) input in field K of the PELAS Bulk Data Entry.
Bulk Data Entry Issues a WARNING when the stiffness value for translational components on the CELAS2/CELAS4 or PELAS entry exceeds the specified limit (ELASTLMT).
Bulk Data Entry Used to control the calculation of enforced displacement vectors in a Modal Frequency Response (MFREQ) analysis.
Bulk Data Entry An upper bound for the stiffness ratio below which a degree of freedom will be regarded as an AUTOSPC candidate.
Bulk Data Entry The ERP output.
Bulk Data Entry The speed of sound used in the ERP calculation.
Bulk Data Entry Specifies the reference power value used to calculate Equivalent Radiated Power (ERP) in decibels (dB).
Bulk Data Entry The fluid density used in ERP calculations.
Bulk Data Entry The Radiation Loss Factor used in ERP calculation.
Bulk Data Entry Controls the output of the AVL/EXCITE .exb file directly from OptiStruct.
Bulk Data Entry This parameter controls the output of the AVL EXCITE _AVL.op2 file directly from OptiStruct.
Bulk Data Entry Activates a nonlinear expert system to aid in the convergence of nonlinear (static and transient) analysis.
Bulk Data Entry This parameter controls the element integration scheme for Nonlinear Explicit Analysis.
Bulk Data Entry EXTOUT controls the output of reduced matrices to external data files for use in subsequent analyses.
Bulk Data Entry Activates the fast contact algorithm. This algorithm can only be used if the nonlinearity in the model comes from just contact (no friction allowed).
Bulk Data Entry Controls the activation of a faster, alternative method (FASTFR) for Modal Frequency Response Analysis.
Bulk Data Entry Used to activate the external FastFRS (Fast Frequency Response Solver).
Bulk Data Entry Defines a frequency cut-off value in Hertz used to partition the structural system into low frequency and high frequency parts.
Bulk Data Entry Defines the amount of memory in Gigabytes to be used by the external FastFRS modal equation solver.
Bulk Data Entry Defines the number of CPUs to be used by the external FastFRS solver.
Bulk Data Entry Used to automatically fix invalid RBE3’s.
Bulk Data Entry Generates flexh3d files for flexible bodies in an MBD analysis.
Bulk Data Entry Allows tetrahedral elements to invert during shape optimization.
Bulk Data Entry Calculation of follower forces introduced by pressure loads and concentrated forces in large displacement nonlinear analysis.
Bulk Data Entry Defines multiplier for K2PP reference.
Bulk Data Entry Identifies the maximum frequency of a rigid body mode for the Lanczos eigensolver.
Bulk Data Entry Specifies the uniform structural damping coefficient for dynamic analyses.
Bulk Data Entry Controls the contribution of material damping, in addition to the stiffness contribution in the element force calculation for frequency response analysis.
Bulk Data Entry Controls the contribution from damping, in addition to the stiffness contribution in the element force calculation for Linear Transient Analysis.
Bulk Data Entry Modifies specified GE values.
Bulk Data Entry Specifies the uniform fluid damping coefficient for dynamic analyses.
Bulk Data Entry Applies to Global-Local Modeling. Expanding the interpolation patch results in a smoother solution near the cut surface.
Bulk Data Entry Controls the accuracy of the external AMLS eigenvalue solution.
Bulk Data Entry Controls where the grid point stresses are calculated for output to the .mnf file.
Bulk Data Entry Obsolete Nastran parameter that will give information about the mass properties of the structure.
Bulk Data Entry The CMASS1 and CMASS2 elements are included or excluded in the Grid Point Weight Generation output.
Bulk Data Entry Controls the output format of the .grid file.
Bulk Data Entry Activates/deactivates the calculation of 1D Gyroscopic Matrix for 1D Rotors in Rotor dynamics.
Bulk Data Entry Used to select the frequency response analysis formulation type for rotor dynamics analysis.
Bulk Data Entry Controls the inclusion or exclusion of shear effect in the beam gyroscopic matrix.
Bulk Data Entry Enables hash-table based assembly.
Bulk Data Entry Controls the output format of the Hierarchical Data result file (HDF5).
Bulk Data Entry Specifies the upper bound of the frequency range of interest for modal combination.
Bulk Data Entry Excludes modes with frequencies greater than HFREQFL in Coupled Modal Frequency Response Analysis (Acoustic Analysis).
Bulk Data Entry Used to turn on or off the check for negative and very large compliance values.
Bulk Data Entry Controls the hourglass type.
Bulk Data Entry On-the-fly incremental results of nonlinear implicit (static and transient) analysis.
Bulk Data Entry Controls the calculation of inertia relief.
Bulk Data Entry Generates the .interface file to verify if proper connection has been established between the Fluid and Structure meshes at the interface.
Bulk Data Entry Inertia relief for nonlinear analysis.
Bulk Data Entry Controls the application of initial stress over the nonlinear subcase.
Bulk Data Entry Writes the 'Tape Label' at the beginning of the OUTPUT2 results file.
Bulk Data Entry Sets cut-off value if the low rank representation for the structural damping matrix is selected.
Bulk Data Entry Specifies the value of PARAM,LOWRANK, which indicates the solution type for the faster Modal Frequency Response solution method invoked by PARAM,FASTFR and the FastFRS interface invoked by PARAM,FFRS.
Bulk Data Entry Enters viscous modal damping into the stiffness matrix as structural damping.
Bulk Data Entry Include contributions from rigid elements in the geometric stiffness matrix.
Bulk Data Entry Controls the creation of the condensed stiffness matrix in an ASCII file to be used by the KISSsoft program.
Bulk Data Entry Control stiffness calculations in linear analysis that is preloaded with small displacement NLSTAT analysis.
Bulk Data Entry Beneficial for problems involving a combination of plasticity, contact, and pretension.
Bulk Data Entry Used to remove the Rigid Body Modes from the Modal Space.
Bulk Data Entry Excludes modes with frequencies lower than LFREQFL in Coupled Modal Frequency Response Analysis (Acoustic Analysis).
Bulk Data Entry This parameter can be used to request only the modes (structural or coupled) that satisfy the lower bound of frequency, for H3D output.
Bulk Data Entry Activates Large Displacement Nonlinear Analysis.
Bulk Data Entry Outputs the condensed Flex Body Modes, full Diagonal Mass Matrix, and modal stresses to the .op2 file.
Bulk Data Entry This parameter is obsolete. Use PARAM,K4METH to control the value of LOWRANK.
Bulk Data Entry In the small displacement NLSTAT solution that has difficulties converging, the “expert system” will try, among other remedies, activation of Line Search.
Bulk Data Entry For static condensation with ASET of a static loadcase, the reduced stiffness matrix [k] and load vector {p} are created.
Bulk Data Entry Identifies the maximum number of residual vectors to be calculated.
Bulk Data Entry Defines the maximum allowed value of the ratio of terms on the diagonal of the stiffness matrix to the corresponding diagonal terms of the triangular factor matrix during decomposition.
Bulk Data Entry Choose the type of the results output to the .h3d file for MBD analyses.
Bulk Data Entry Creates small and large flexible body files during Component Mode Synthesis (CMS).
Bulk Data Entry Controls the participation of elements removed by MODCHG in the analysis.
Bulk Data Entry Controls the internal calculation of material damping when different material damping values (GE on MATx) are specified for different regions in a model.
Bulk Data Entry Activates/deactivates the memory-trim feature when using AMLS eigensolver.
Bulk Data Entry Defines a threshold for the mode tracking matrix to check eigenvector correspondence.
Bulk Data Entry Tracks mode numbers by comparing eigenvectors between iterations.
Bulk Data Entry Controls the auto SPC of degrees of freedom with both mass and viscous damping.
Bulk Data Entry Identifies whether the Number of Peaks or Number of Zero Crossings are used for NARROW band model in Random Response Fatigue Analysis.
Bulk Data Entry Allows run to proceed with negative diagonal mass terms.
Bulk Data Entry Used to control switching between alternative and traditional constraint reduction methods.
Bulk Data Entry Forces OptiStruct to run models in which fatigue solutions reference small displacement nonlinear analysis (NLSTAT) subcases.
Bulk Data Entry The optimization process involving nonlinear analysis, in the subsequent optimization iteration the solution of the nonlinear problem.
Bulk Data Entry This parameter activates Nonlinear Results Monitoring. Currently, only displacement results monitoring is available.
Bulk Data Entry Frequency for output control. OptiStruct will write results to the .out file in every NOUTCYC step.
Bulk Data Entry Controls the number of the output INFORMATION #741 for RBAR element.
Bulk Data Entry Controls the number of the output INFORMATION #741 for RBE2 element.
Bulk Data Entry Controls the number of the output INFORMATION #742.
Bulk Data Entry Specifies the anticipated number of modes to be calculated in order to estimate disk space usage.
Bulk Data Entry An Operating Deformed Shape (ODS) run requires the output for all the elements or all the grids for limited loading frequencies of interest.
Bulk Data Entry Outputs model data to the OUTPUT2 results file.
Bulk Data Entry Selects newer version of certain OUTPUT2 datablocks.
Bulk Data Entry Outputs stress and strain results for shell and membrane elements with reference to the material coordinate system.
Bulk Data Entry Controls the output of GEOM3 and GEOM4 data blocks to the .op2 file.
Bulk Data Entry The value of PARAM,ORIGK4 is used to replace the GE damping field on any material Bulk Data Entry referenced by superelements.
Bulk Data Entry This parameter limits the applicability of PARAM,PBUSHTF properties.
Bulk Data Entry Used to turn ON/OFF the usage of all PBUSHT Bulk Data Entries in the model.
Bulk Data Entry Specifies the reference frequency value for scaling factor lookup to update the nominal PBUSH Stiffness (K) values.
Bulk Data Entry Controls the output of the .eactdmg file for Pseudo Damage method in fatigue analysis.
Bulk Data Entry Used to turn ON/OFF the usage of all PELAST Bulk Data Entries in the model.
Bulk Data Entry Prints the applied load vector in DMIG form to the .pligext file.
Bulk Data Entry Increases the starting size of panel to the specified value.
Bulk Data Entry Generates an OUTPUT2 results file.
Bulk Data Entry Outputs the modal complex stiffness matrix and modal viscous damping matrix to the OUTPUT2 results file.
Bulk Data Entry Forces OptiStruct to run models in which Linear Buckling Analysis or Preloaded Analysis is defined, in conjunction with nonlinear materials (MATS1, MATHE, or MGASK) or Large Displacement Nonlinear Analysis.
Bulk Data Entry Outputs AUTOSPC information to the .out file.
Bulk Data Entry Controls the output of inertial relief rigid body forces and accelerations.
Bulk Data Entry Controls the printing of Design Variables and Design Entities to the .out file.
Bulk Data Entry Defines the maximum number of contributions printed for each norm response under the norm response itself in the .out file for an Optimization run.
Bulk Data Entry Controls the printing of Retained Response information to the .out file.
Bulk Data Entry Defines the Mass Matrix.
Bulk Data Entry The PSD/RMS Absolute Maximum Principal Stress for Random Response Analysis is output or not.
Bulk Data Entry Used to convert ERROR 725 into WARNING 825 when singular RBE2 elements are present in the model.
Bulk Data Entry This parameter controls the handling of RBE3 elements.
Bulk Data Entry Used to convert ERROR 772 into WARNING 824 when free spiders on RBE3 elements are present in the model. These free spiders may contain singular degrees-of-freedom.
Bulk Data Entry Defines the cut-off eigenvalue for determining rigid body modes calculated by AMLS.
Bulk Data Entry Reanalyze the final iteration of a topology optimization without penalization.
Bulk Data Entry Allows you to request full-structure global mode shape output instead of the modes of the condensed system generated during Component Mode Synthesis (CMS).
Bulk Data Entry The reference point for Inertia Relief of the model.
Bulk Data Entry Allows you to correctly renumber the reversed (but acceptable) sequence of element grids without having to run (import and re-export) the model through HyperMesh.
Bulk Data Entry Controls the output of modal super element for use in the RecurDyn multibody dynamics software from FunctionBay.
Bulk Data Entry The scale factor used to calculate ERP in decibels (dB).
Bulk Data Entry Controls the creation of the condensed flex body modes and full diagonal mass matrix to the .op2 file to be used by VALDYN from Ricardo Software.
Bulk Data Entry Controls the creation of the condensed stiffness, mass, and displacement recovery matrices for use with Romax Technology.
Bulk Data Entry RSPLINE end rotation correction.
Bulk Data Entry Controls the creation of analysis results to be used by the STRENGTH2000 program to the .op2 file.
Bulk Data Entry Used to modify the tolerance value for symmetric beams when they are used for rotor modeling.
Bulk Data Entry The old and new location of moved shell grid points are printed if SEP1XOVR = 16.
Bulk Data Entry Outputs display model to .seplot file, from a CMS run.
Bulk Data Entry Activate an alternative 1st order Nonlinear Large Displacement shell element (CQUAD4 and CTRIA3 elements).
Bulk Data Entry Identifies the handling of nodal shell thicknesses defined on the shell element entries.
Bulk Data Entry Allows you to revert to the first order shell element formulation (for CQUAD4 and CTRIA3) used in version 11.0.240 and earlier.
Bulk Data Entry A shell property (defined by the PSHELL Bulk Data Entry) is automatically converted into a membrane property if the membrane thickness (field T) of the PSHELL Bulk Data Entry is less than the value specified using PARAM, SHL2MEM.
Bulk Data Entry Defines the type and order of approximation used in plate bending geometric stiffness for linear shell elements (CQUAD4, CTRIA3).
Bulk Data Entry The Stefan-Boltzmann constant used in Radiation Heat Transfer calculations.
Bulk Data Entry Requests generation of the SIMPACK .fbi file containing flexible body information for SIMPACK analysis.
Bulk Data Entry This parameter can be used to select the SIMPACK version for multibody dynamics analysis.
Bulk Data Entry Controls the output of violated constraints to the .out file from an optimization.
Bulk Data Entry Specifies the speed of sound used in the wave number and the complex particle velocity vector calculations.
Bulk Data Entry Specifies the scale factor (q) used to calculate the Sound Pressure Level in Radiated Sound Analysis.
Bulk Data Entry Specifies the reference sound pressure value used to calculate the Sound Pressure Level (SPL) in decibels (dB).
Bulk Data Entry Specifies the density of the acoustic medium in the calculation of the complex acoustic sound pressure and the complex particle velocity vector.
Bulk Data Entry Outputs the strength ratios for composite elements that have failure indices requested.
Bulk Data Entry Used to specify the von Mises stress threshold above which the stress results are output for a model.
Bulk Data Entry Converts units of the temperature input (Fahrenheit or Celsius) to the absolute temperature (Degrees Kelvin).
Bulk Data Entry Defines the lower threshold value used for the HyperMesh command files *.HM.comp.tcl and *.HM.ent.tcl.
Bulk Data Entry Defines the step or interval value used for the HyperMesh command files *.HM.comp.tcl and *.HM.ent.tcl.
Bulk Data Entry Controls the penalty factor used in thermal contact analysis.
Bulk Data Entry Select the thermal strain formula.
Bulk Data Entry Connecting grid points of the shell element are moved onto the solid face.
Bulk Data Entry Used to select the criterion employed for mode tracking.
Bulk Data Entry Controls output of the mode tracking matrix during optimization.
Bulk Data Entry Activates fast transient response analysis (only shell stress results output).
Bulk Data Entry Specifies the coordinate system in which the mass moment of inertia is output. It also can be used to control the point about which the mass moment of inertia is calculated.
Bulk Data Entry This parameter can be used to request only the modes (structural or coupled) that satisfy the upper bound of frequency, for H3D output.
Bulk Data Entry Outputs the UHT data block.
Bulk Data Entry This parameter is used to convert an unsymmetrical K2PP or M2PP matrix to a symmetrical matrix.
Bulk Data Entry Controls the inclusion or exclusion of non-symmetric terms in the tangent stiffness matrix due to friction in frictional contact problems.
Bulk Data Entry Used with MFLUID and PARAM,GRDPNT.
Bulk Data Entry Allows you to prevent the inclusion of the Virtual Mass Matrix in the Regular Mass Matrix for Modal Dynamic Subcases. In such cases, the virtual mass is added after the eigen solution and modes are modified based on the virtual mass matrix.
Bulk Data Entry Used in aeroelastic flutter analysis to specify a factor to divide the velocities.
Bulk Data Entry Converts structural damping to equivalent viscous damping for transient analysis.
Bulk Data Entry Used to include or exclude rotor material hybrid damping in rotor dynamics analysis.
Bulk Data Entry Used to include or exclude rotor structural damping in rotor dynamics analysis.
Bulk Data Entry Used to include or exclude rotor material damping in rotor dynamics analysis.
Bulk Data Entry Converts weights to masses using this multiplier.
Bulk Data Entry Used to create the .elfo (element forces), .elsh (element shear), and .endl (end loads) output files.
Bulk Data Entry Outputs an ASCII file (.zaero) containing the normal modes data for the requested grids. This file can be used to import into ZAERO software, for further aeroelastic analysis.
Bulk Data Entry Defines the properties of axisymmetric elements. Referenced by CTAXI and CQAXI entries.
Bulk Data Entry Defines the properties of a simple beam (bar), which is used to create bar elements via the CBAR entry.
Bulk Data Entry Defines the properties of a simple beam (bar) by cross-sectional dimensions, which is used to create bar elements via the CBAR entry.
Bulk Data Entry Defines additional BAR properties for geometric nonlinear analysis.
Bulk Data Entry Defines the properties of beam elements defined via the CBEAM entry.
Bulk Data Entry Defines the properties of a beam element by cross-sectional dimensions that are used to create beam elements via the CBEAM entry.
Bulk Data Entry Defines additional BEAM properties for geometric nonlinear analysis.
Bulk Data Entry Defines the nominal property values for a generalized spring-damper-mass structural element.
Bulk Data Entry Defines the linear and nonlinear properties for a one-dimensional spring-and-damper structural element.
Bulk Data Entry Defines the various nominal property values for a generalized spring-damper-mass structural element. This property is not affected by translational and rotational stiffness limits specified using PARAM, BUSHSTIF.
Bulk Data Entry Defines property values for a generalized spring and damper structural element.
Bulk Data Entry Defines properties TYPE2 tied CONTACT interface for geometric nonlinear analysis.
Bulk Data Entry Defines properties TYPE7 of a CONTACT interface for geometric nonlinear analysis.
Bulk Data Entry Defines properties TYPE11 of a CONTACT interface for geometric nonlinear analysis.
Bulk Data Entry Defines properties TYPE20 of a CONTACT interface for geometric nonlinear analysis.
Bulk Data Entry Defines properties TYPE24 of a CONTACT interface for geometric nonlinear analysis.
Bulk Data Entry Defines the properties for cohesive elements.
Bulk Data Entry Defines the structure and properties of an n-ply composite laminate material.
Bulk Data Entry Defines the structure and properties of a composite laminate material, allowing for global ply identification.
Bulk Data Entry Defines global ply-based composite properties for continuum shell composites.
Bulk Data Entry Defines the properties of a composite laminate material used in ply-based composite definition.
Bulk Data Entry Defines additional composite laminate properties for geometric nonlinear analysis.
Bulk Data Entry Defines properties of a CONTACT interface.
Bulk Data Entry Defines Contact Electric Coefficient (CEC) for CONTACT elements in electrical analysis.
Bulk Data Entry Defines conductance for CONTACT elements in heat transfer analysis.
Bulk Data Entry Defines properties of a CONTACT interface for geometric nonlinear analysis.
Bulk Data Entry Defines a free convection boundary condition properties.
Bulk Data Entry Defines the external function to be called to calculate time and temperature-dependent free-convection coefficient in a convection element.
Bulk Data Entry Specifies the damping of a scalar damper element using defined CDAMP1 or CDAMP3 entry.
Bulk Data Entry Defines criteria used for the automatic identification of loading frequencies at which result peaks occur. Other result output may then be requested at these "peak" loading frequencies. This feature is only supported for frequency response solution sequences.
Bulk Data Entry Used to define the stiffness and stress coefficient of a scalar elastic element (spring) by means of the CELAS1 or CELAS3 entry.
Bulk Data Entry Defines the frequency dependent property values for a PELAS Bulk Data Entry. It can also be used to define a nonlinear spring for Nonlinear Analysis via the TKNID field.
Bulk Data Entry Defines a connection between opposite edges/faces of the structure. This entry is used to apply Periodic Boundary Conditions to the model.
Bulk Data Entry Define properties of connector (CFAST) elements.
Bulk Data Entry Defines element properties for fatigue analysis.
Bulk Data Entry Defines properties for solder fatigue analysis.
Bulk Data Entry Defines properties for Seam Weld Fatigue Analysis.
Bulk Data Entry Defines properties for Spot Weld Fatigue Analysis.
Bulk Data Entry Defines a one-step transfer path analysis.
Bulk Data Entry Defines a flexible body out of a list of finite element properties, elements, and grid points.
Bulk Data Entry Defines properties of the gap (CGAP or CGAPG) elements.
Bulk Data Entry Defines electrical resistance properties for the gap elements (CGAP or CGAPG) in electrical analysis.
Bulk Data Entry Defines heat transfer conduction properties of the gap (CGAP or CGAPG) elements for heat transfer analysis.
Bulk Data Entry Defining the properties for solid gasket elements.
Bulk Data Entry Defines the thickness, material, blank holder, binder and Forming Limit Curve references for a shell property in a one-step stamping simulation.
Bulk Data Entry Defines the properties for a Joint connection between two grids via the JOINTG entry.
Bulk Data Entry Defines a static pressure load on a triangular or quadrilateral element. It can also be used to define the EXCITEID field (Amplitude "A") of dynamic loads in RLOAD1, RLOAD2, TLOAD1 and TLOAD2 Bulk Data Entries.
Bulk Data Entry Defines concentrated, uniformly distributed, or linearly distributed applied loads to the CBAR or CBEAM elements or a SET of such elements at user-chosen points along the axis.
Bulk Data Entry Defines a uniform static pressure load applied to two-dimensional elements, or a SET of such elements.
Bulk Data Entry Defines a load on a face of a HEXA, PENTA, TETRA, PYRA, TRIA3, TRIA6, QUAD4, or QUAD8 element.
Bulk Data Entry Defines an in-plane surface traction on the edge of CTPSTN and CQPSTN elements.
Bulk Data Entry Parameters of pressure loads on a surface defined by a SURF Bulk Data Entry or SET Bulk Data Entry.
Bulk Data Entry Defines a static surface traction on the CQAXI, CTAXI and CTRIAX6 axisymmetric elements. The PLOADX1 entry can be defined as follower loads in Large Displacement Nonlinear Analysis.
Bulk Data Entry Defines a one-dimensional dummy element for use in plotting.
Bulk Data Entry Defines a three-noded, two-dimensional dummy element for use in plotting.
Bulk Data Entry Defines a four-noded, two-dimensional dummy element for use in plotting.
Bulk Data Entry Defines the properties of nonlinear hyperelastic solid elements, referenced by CHEXA, CPENTA, and CTETRA Bulk Data Entries. The MATHE hyperelastic material can be referenced to define corresponding material properties.
Bulk Data Entry Defines the properties of a ply used in ply-based composite definition.
Bulk Data Entry Defines the mass value of a scalar mass element (CMASS1 or CMASS3 entry).
Bulk Data Entry Defines the properties of plane strain elements (CTPSTN and CQPSTN).
Bulk Data Entry Defines a rigid body out of a list of finite element properties, elements and grid points.
Bulk Data Entry Defines 1D or 3D pre-tensioned bolt section.
Bulk Data Entry Defines parameters that control initial loading conditions on pretension sections for 1D and 3D bolt pre-tensioning. These parameters also control the printing of diagnostic information about pretension sections.
Bulk Data Entry Defines the properties of a rod, which is referenced by the CROD entry.
Bulk Data Entry Define properties of connector (CSEAM) elements.
Bulk Data Entry Defines property information for planar section elements used in the definition of arbitrary beam cross-sections.
Bulk Data Entry Defines the properties of a shear panel.
Bulk Data Entry Defines the membrane, bending, transverse shear, and membrane-bending coupling of shell elements.
Bulk Data Entry Defines additional SHELL properties for geometric nonlinear analysis.
Bulk Data Entry Defines additional orthotropic SOLID properties for geometric nonlinear analysis.
Bulk Data Entry Defines the properties of solid elements, referenced by CHEXA, CPENTA, CPYRA and CTETRA Bulk Data Entries.
Bulk Data Entry Defines additional SOLID properties for geometric nonlinear analysis.
Bulk Data Entry Defines properties of a contact surface.
Bulk Data Entry Defines a pretension load as a linear combination of load sets defined via PTFORCE, PTFORC1, PTADJST and PTADJS1 entries.
Bulk Data Entry Defines adjustment (additional shortening) on a set of pretension sections.
Bulk Data Entry Defines the adjustment (shortening) on a pretension section.
Bulk Data Entry Defines pretensioning force on pretension section.
Bulk Data Entry Defines pretensioning force on a set of pretension sections.
Bulk Data Entry Defines the properties of a thin-walled cylindrical tube element, referenced by a CTUBE entry.
Bulk Data Entry Defines properties of a one-dimensional viscous damping element (CVISC entry).
Bulk Data Entry Defines properties of connector (CWELD) elements.
Bulk Data Entry Defines a uniform heat flux for CHBDYE elements.
Bulk Data Entry Defines the external function to be called to calculate time and temperature-dependent Uniform Heat Flux values.
Bulk Data Entry Defines a rate of volumetric heat addition in a conduction element.
Bulk Data Entry Defines the external function called to calculate time and temperature-dependent rate of volumetric heat addition in a conduction element.
Bulk Data Entry Defines the radiation boundary conditions and identifies CHBDYE entries for heat transfer analysis via radiation.
Bulk Data Entry Defines the radiation material properties of a surface element for heat transfer analysis.
Bulk Data Entry Defines the parameters for explicit dynamic analysis.
Bulk Data Entry Defines a set of grid points where the sound will be calculated as well as the panels that are generating the sound.
Bulk Data Entry Defines load set power spectral density factors for use in random analysis having the frequency dependent form .
Bulk Data Entry Defines time lag constants for use in random analysis autocorrelation function computation.
Bulk Data Entry Defines a rigid body as a combination of Rigid Bodies (RBODY).
Bulk Data Entry Defines a rigid bar with six degrees-of-freedom at each end.
Bulk Data Entry Defines a rigid body connected to an arbitrary number of grid points.
Bulk Data Entry Defines a rigid body whose independent degrees-of-freedom are specified at a single grid point and whose dependent degrees-of-freedom are specified at an arbitrary number of grid points.
Bulk Data Entry Defines a rigid element connecting two grid points which are closest to the grid point referenced by the field GS.
Bulk Data Entry Defines the motion at a "reference" grid point as the weighted average of the motions at a set of other grid points.
Bulk Data Entry Defines a rigid body as a set of elements, grid points.
Bulk Data Entry Defines a pair of response quantities for computing the cross-power spectral density functions in random response analysis.
Bulk Data Entry Geometrically maps parts (for example, elements and grids) from one location to another. This entry allows you to define mapping as MOVE (translation), ROTATE, MIRROR, or MATCH (as an arbitrary transformation which matches grids from one group to similar grids in another group).
Bulk Data Entry Defines a static loading condition due to a centrifugal force field. It can also be used to define the EXCITEID field (Amplitude "A") of dynamic loads in RLOAD1, RLOAD2 , TLOAD1 and TLOAD2 Bulk Data Entries.
Bulk Data Entry Includes data required to perform Rotor Dynamics analysis in Modal Frequency Response Analysis and/or Modal Complex Eigenvalue Analysis. The RGYRO Bulk Data Entry is referenced by a corresponding RGYRO Subcase Information Entry in a specific subcase.
Bulk Data Entry Defines a Rigid Joint connection at two coincident grids.
Bulk Data Entry Defines a frequency-dependent dynamic load of the form: for use in frequency response problems.
Bulk Data Entry Defines a frequency-dependent dynamic load of the form for use in frequency response problems.
Bulk Data Entry Specifies grids that determine the Rotor Line model.
Bulk Data Entry Defines a pin-ended rod that is rigid in extension.
Bulk Data Entry Specifies directional combination method, modal combination method, excitation direction(s), response spectra and scale factors for Response Spectrum Analysis.
Bulk Data Entry Specifies a set of reference rotor speed values for asynchronous analysis in Rotor Dynamics.
Bulk Data Entry Defines the relative spin rates between rotors and rotor damping parameters during a rotor dynamic analysis in Static, Modal Complex Eigenvalue or Frequency Response solution sequences.
Bulk Data Entry Defines the rotor spin rates and rotor damping parameters with respect to time during a Transient Rotor Dynamics Analysis.
Bulk Data Entry Defines multi-point constraints for the interpolation of displacements at grid points.
Bulk Data Entry Defines multi-point constraints to model clamped connections of shell-to-solid elements.
Bulk Data Entry Defines the degrees of freedom where the residual vectors are to be calculated.
Bulk Data Entry Defines a rigid wall set as a union of rigid walls defined via RWALL entries.
Bulk Data Entry Defines a rigid wall for geometric nonlinear analysis.
Bulk Data Entry Defines superelement boundary search options and the type of superelement.
Bulk Data Entry Defines grid and scalar point connection procedures for a partitioned superelement.
Bulk Data Entry Defines free boundary degrees-of-freedom for One-Step Superelement Analysis.
Bulk Data Entry Defines free boundary degrees-of-freedom to be free for use in One-Step Superelement Analysis (Alternate Format).
Bulk Data Entry Defines a section for force output in geometric nonlinear analysis.
Bulk Data Entry Defines a specific face of a cross-section of the model.
Bulk Data Entry Defines a partitioned superelement relocation by listing three noncolinear grids in the superelement and three corresponding grids not belonging to the superelement.
Bulk Data Entry Defines different types of sensors. Sensors may be used to activate loads.
Bulk Data Entry Defines the generalized degrees-of-freedom of the superelement for use in One-Step Superelement Analysis.
Bulk Data Entry Defines the generalized degrees-of-freedom of the superelement for use in One-Step Superelement Analysis (Alternate Format).
Bulk Data Entry Defines the interior grid points for One-Step Superelement Analysis.
Bulk Data Entry Defines a set of grids, elements, design variables, MBD entities, mode numbers, frequencies or times for reference by other input definitions.
Bulk Data Entry Defines a list of structural grid points or element identification numbers.
Bulk Data Entry Defines a set of grids or elements.
Bulk Data Entry Defines the Superelement Tree for One-Step Superelement Analysis.
Bulk Data Entry Defines concentrated static loads on scalar, grid or fluid points.
Bulk Data Entry Defines the solver type to be used for static and dynamic analysis.
Bulk Data Entry This entry can be used to define single-point constraints, enforced displacements for Structural analysis or Temperature boundary conditions for Thermal (steady-state and transient heat transfer) analysis or electric potential for Electrical analysis.
Bulk Data Entry Defines sets of single-point constraints and thermal boundary conditions.
Bulk Data Entry Defines a single-point constraint set as a union of single-point constraint sets defined via SPC or SPC1 entries.
Bulk Data Entry This entry can be used to define enforced displacement value for static analysis or enforced displacement, velocity, or acceleration for dynamic analysis or enforced temperature for Thermal (steady-state and transient heat transfer) analysis or enforced electric potential for Electrical analysis.
Bulk Data Entry Defines the external function to be called to calculate time and temperature-dependent SPCD temperature values.
Bulk Data Entry Defines degrees-of-freedom to be excluded from AUTOSPC.
Bulk Data Entry Defines the flow pressure boundary conditions for Darcy Flow Analysis.
Bulk Data Entry Defines a surface spline for interpolating motion and forces for aeroelastic problems on aerodynamic geometries defined by regular arrays of aerodynamic points.
Bulk Data Entry Defines a beam spline for interpolating motion and/or forces for aeroelastic problems on aerodynamic geometries defined by regular arrays of aerodynamic points.
Bulk Data Entry Defines a curved surface spline for interpolating motion and forces for aeroelastic problems on aerodynamic geometries.
Bulk Data Entry Defines scalar points.
Bulk Data Entry Defines the stacking information and stacking sequence for ply-based composite definition.
Bulk Data Entry Defines determinate reaction degrees-of-freedom in a free body.
Bulk Data Entry Defines a face of a shell or solid (3D solid, axisymmetric solid, or plane-strain solid) element as part of a surface.
Bulk Data Entry Defines values of parameters used during the CWELD and CSEAM connectivity search.
Bulk Data Entry Defines modal damping as a tabular function of natural frequency.
Bulk Data Entry Defines modal damping as a tabular function of mode index.
Bulk Data Entry Defines y values of each point on the loading time history.
Bulk Data Entry Defines a tabular function for use in generating frequency-dependent and time-dependent dynamic loads.
Bulk Data Entry Defines a tabular function for use in generating frequency-dependent and time-dependent dynamic loads. Also contains parametric data for use with the table.
Bulk Data Entry Defines the coefficients of a power series for use in generating frequency-dependent and time-dependent dynamic loads. Also contains parametric data for use with the table.
Bulk Data Entry Defines a general tabular function for use in supported reference entries.
Bulk Data Entry Defines a tabular function for use in generating temperature-dependent material properties.
Bulk Data Entry Defines a tabular function for use in generating temperature-dependent material properties. Also contains parametric data for use with the table.
Bulk Data Entry Defines coefficients of a power series for use in generating temperature-dependent material properties. Also contains parametric data for use with the table.
Bulk Data Entry Defines a multi-dimensional tabular function which identifies single or multiple X-values for a single Y-value.
Bulk Data Entry Defines a tabular function for material and friction property.
Bulk Data Entry Specifies the material property tables for elasto-plastic, temperature-dependent materials.
Bulk Data Entry Defines a tabular function for Stress (X) - Life (Y) pairs to define an SN curve.
Bulk Data Entry Defines power spectral density as a tabular function of frequency for use in random analysis. Referenced on the RANDPS entry.
Bulk Data Entry Defines temperature at grid points or a SET of grid points for determination of Thermal Loading and Stress recovery.
Bulk Data Entry Defines a temperature value for all grid points of the structural model that have not been given a temperature on a TEMP entry.
Bulk Data Entry Defines temperature field for shell elements (as a combination of reference plane temperature and linear thermal gradient through thickness) for determination of thermal loading, temperature-dependent material properties and stress recovery.
Bulk Data Entry Defines parameters for mapping the grid temperature field from either an external file or an internal heat transfer subcase to Nonlinear Static Analysis. The mapping is over time-domain only.
Bulk Data Entry Defines values for the initial conditions of variables used in structural transient analysis and explicit analysis. Both displacement and velocity values may be specified at independent degrees-of-freedom.
Bulk Data Entry Defines values for the initial velocity of a set of grids along and about an axis for explicit analysis.
Bulk Data Entry Defines a tied contact.
Bulk Data Entry Defines a time-dependent dynamic load or enforced motion.
Bulk Data Entry Defines a time-dependent dynamic excitation or enforced motion.
Bulk Data Entry Specifies the constraints for aeroelastic trim variables.
Bulk Data Entry Defines time step parameters for control and intervals at which a solution will be generated and output in transient analysis.
Bulk Data Entry Defines parameters for Nonlinear Direct Transient Analysis.
Bulk Data Entry Defines time step parameters for control and intervals at which a solution will be generated and output in explicit analysis.
Bulk Data Entry Defines the unbalanced rotating load during a rotor dynamic analysis in Modal Frequency Response, Linear Direct Transient or Small Displacement Nonlinear Direct Transient solution sequences. The unbalanced load is specified in a cylindrical system where the rotor rotation axis is the Z-axis.
Bulk Data Entry Defines a set of degrees-of-freedom.
Bulk Data Entry Defines parameters for nonlinear analysis involving time-dependent material behavior.
Bulk Data Entry Defines the values for Raleigh damping for geometric nonlinear dynamic analysis.
Bulk Data Entry Defines a time history output set as a union of time history outputs defined via XHIST entries.
Bulk Data Entry Defines the time history output request for geometric nonlinear analysis.
Bulk Data Entry Defines default shell element parameters for geometric nonlinear analysis.
Bulk Data Entry Defines default SOLID properties for geometric nonlinear analysis.
Bulk Data Entry Defines explicit analysis control.
In order to prevent analyses from being carried out on badly discretized models, an element quality check is incorporated into the pre-processing phase.
In order to prevent analyses from being carried out on models with poor material definitions, a material property check is incorporated into the pre-processing phase. The material property check is controlled by the CHECKMAT parameter (see the PARAM input format).
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides you with examples of the real-world applications and capabilities of OptiStruct.
This manual presents solved verification models including NAFEMS problems.
This section provides quick responses to typical and frequently asked questions regarding OptiStruct.
This manual provides a detailed list and usage information regarding input entries, output entries, and parameters available in OptiStruct.
Alphabetical listing of the Bulk Data Entries.
Bulk Data Entry Switch between relative and absolute displacement output in Modal Frequency Response Analysis with enforced motion.
| Parameter | Values | Description |
| ENFMOTN | <ABS, TOTAL, or REL> |
