PARAM, AMLSNCPU
Bulk Data Entry Used to define the number of CPUs to be used by the external AMLS eigenvalue solver.
| Parameter | Values | Description |
| AMLSNCPU | Integer ≥ 1 Default = 1 |
This parameter is used to
AMLS eigenvalue solver. Refer to AMLS (Automatic Multi-level Sub-structuring) Eigensolver in the User Guide for more details. |
- OptiStruct and AMLS can be run with different allocations of processors. For example, OptiStruct can be run with 1 processor and AMLS with 4 processors in the same run.
- PARAM,AMLSNCPU is only valid when PARAM, AMLS is set to YES.
