PARAM, TABS
Bulk Data Entry Converts units of the temperature input (Fahrenheit or Celsius) to the absolute temperature (Degrees Kelvin).
| Parameter | Values | Description |
| TABS | <
Real > Default = 0.0 |
Absolute temperature
scale factor. If the temperature input is in Celsius, then PARAM,TABS,273.16 should be used. If the temperature input is in Fahrenheit, then PARAM,TABS,459.69 should be used. |
