TRIM
Bulk Data Entry Specifies the constraints for aeroelastic trim variables.
| TRIM | SID | MACH | Q | LABEL1 | UX1 | LABEL2 | UX2 | AEQR | |
| LABEL3 | UX3 | etc. |
| TRIM | 23 | 0.8 | 110.0 | URDD3 | 1.0 | ANGLEA | 6.0 | 0.0 | |
| URDD5 | 0.3 |
| SID | Trim set identification number. 1
2 (Integer > 0) |
| MACH | Mach number. (0.0 ≤ Real < 1.0) |
| Q | Dynamic pressure. (Real > 0.0) |
| LABELi | The label identifying aerodynamic trim variables defined on
an AESTAT or AESURF
entry. (Character) |
| UXi | The magnitude of the aerodynamic extra point degree of
freedom. (Real) |
| AEQR | Flag to request a rigid trim analysis.
(0.0 ≤ Real ≤ 1.0) |
- The TRIM entry should be selected with the Case Control command TRIM.
- The SID should be unique among all the TRIM entries.
- The selected TRIM entry specifies the constrained values of the listed extra point degrees-of-freedom (“trim variables”) for a particular loading condition. These variables are listed on AESTAT and/or AESURF entries.
