CWELD
Bulk Data Entry Defines a weld or fastener connecting two surface patches or points.
| CWELD | EWID | PWID | GS | TYP | GA | GB | SPTYP | ||
| GA1/ SHIDA |
GA2/ SHIDB |
GA3 | GA4 | GA5 | GA6 | GA7 | GA8 | ||
| GB1 | GB2 | GB3 | GB4 | GB5 | GB6 | GB7 | GB8 |
Example 1
| CWELD | 7 | 34 | 233 | GRIDID | QT | ||||
| 55 | 56 | 21 | 22 | ||||||
| 101 | 102 | 378 |
Example 2
| CWELD | 7 | 34 | 233 | ELEMID | |||||
| 15 | 16 |
Example 3
| CWELD | 7 | 34 | ALIGN | 103 | 259 |
Alternate Formats of CWELD Card - PARTPAT/ELPAT
The alternative formats of CWELD listed below are useful in cases when the weld diameter extends beyond a single shell element. These options connect up to 3x3 shell elements per patch (possibly more for triangular elements) on each side of weld element.
Format (Alternate)
| CWELD | EWID | PWID | GS | PATCHTYP | GA | GB | |||
| PIDA/ SHIDA |
PIDB/ SHIDB |
| XS | YS | ZS |
Example 1 (Alternate)
| CWELD | 10 | 20 | PARTPAT | ||||||
| 33 | 34 | ||||||||
| 5.0 | 5.0 | 0.0 |
Example 2 (Alternate)
| CWELD | 10 | 20 | 345 | ELPAT | |||||
| 1034 | 2035 |
| EWID | Unique element identification
number. No default (Integer > 0) |
| PWID | A PWELD entry identification number. Default = EWID (Integer > 0) |
| GS | Identification number of a
grid point which defines the location of the connector. Required
when TYP is GRIDID or
ELEMID and GA and
GB are unspecified. 2
4 No default (Integer > 0 or <PartName.number>) 14 |
| TYP | Character string
indicating how the connection is defined.
| GA, GB | When
TYP is GRIDID or
ELEMID, these represent grid identification
numbers of piercing points on surface A and surface B, respectively.
4 When TYP is ALIGN, these represent vertex grid identification numbers of the first and second shells, respectively. No default (Integer > 0 or <PartName.number>) 14 |
| SPTYP | String indicating types of
surface patches A and B.
No default (QQ, TT, QT, TQ, Q or T) |
| GA# | Grid identification
numbers of the first surface patch. GA1 to
GA3 are required. 6 No default (Integer > 0 or <PartName.number>) 14 |
| GB# | Grid identification
numbers of the second surface patch. 6 Default = blank (Integer > 0 or <PartName.number>) 14 |
| PATCHTYP | Connection type between
the patches. Either format connects up to 3x3 elements per patch
(possibly more for triangular elements). 12
| PIDA, PIDB | Property identification
numbers of PSHELL entries defining surface A and
B, respectively. Required for PARTPAT. Integer > 0, PIDA ≠ PIDB |
| SHIDA, SHIDB | Element identification
numbers of shells defining weld ends A and B, respectively. Required
for ELPAT. Integer > 0, SHIDA ≠ SHIDB |
| XS, YS, ZS | Coordinates of point that
defines the location of the weld in the basic coordinate system. It
is an alternate way of specifying the location of
GS. Available with
PARTPAT/ELPAT options
only. Real |
- CWELD defines a flexible
connection between two surface patches, between a point and a surface patch, or
between two shell vertex grid points.
Figure 1. Connection Between Two Surface Patches
Figure 2. Connection Between a Point and a Surface Patch
Figure 3. Connection Between Two Shell Vertex Grid Points - GS is ignored, if TYP is ALIGN.
- If TYP is GRIDID, either a point to patch (GS to GA#) or a patch to patch (GA# to GB#) connection is defined. For the patch to patch connection, GA# describes the first surface patch and GB# describes the second surface patch.
- The input of the piercing points GA and GB is optional when TYP is GRIDID and ELEMID. If GA or GB are not specified, they are generated from the normal projection of GS onto the surface patches. If GA and/or GB are specified, they take precedence over GS in defining the respective end points. Also, their locations will be corrected so that they lie on surface patch A and B, respectively. If GS is not specified, both GA and GB are required. The length of the connector is the distance from GA to GB.
- SPTYP defines the type of
surface patches to be connected. SPTYP is required when
TYP is GRIDID to identify quadrilateral or
triangular patches. Valid combinations are:
- SPTYP
- Description
- Connects a quadrilateral surface patch A (QUAD4 or QUAD8) with a quadrilateral surface patch B (QUAD4 or QUAD8).
- QT
- Connects a quadrilateral surface patch A (QUAD4 or QUAD8) with a triangular surface patch B (TRIA3 or TRIA6).
- TT
- Connects a triangular surface patch A (TRIA3 or TRIA6) with a triangular surface patch B (TRIA3 or TRIA6).
- TQ
- Connects a triangular surface patch A (TRIA3 or TRIA6) with a quadrilateral surface patch B (QUAD4 or QUAD8).
- Q
- Connects a grid point GB (or GS if GB not provided) with a quadrilateral surface patch A (QUAD4 or QUAD8). Surface patch B should not be specified.
- T
- Connects a grid point GB (or GS if GB not provided) with a triangular surface patch A (TRIA3 or TRIA6). Surface patch B should not be specified.
- GA# are required when
TYP is GRIDID. At least 3, and at most 8,
grid IDs may be specified for GA#. Triangular and quadrilateral
element definition sequences apply for the order of GA# and
GB#. Missing mid-side nodes are allowed.
Figure 4. Quadrilateral and Triangular Surface Patches as Defined when TYP is GRIDID - When TYP is ELEMID, a point to patch connection is defined, GS to SHIDA or a patch to patch connection, SHIDA to SHIDB. SHIDA and SHIDB must be valid shell element identification numbers.
- When TYP is ALIGN, a point to point connection is defined. GA and GB are required. GA and GB are not required when TYP is GRIDID or ELEMID.
- Forces and moments are output in the element
coordinate system.
The element x-axis points from GA to GB. The element y-axis lies on the plane created by the element x-axis and the smallest component of the element x-axis is the basic coordinate system, and is orthogonal to the element x-axis. The element z-axis is the cross-product of the element x-axis and the element y-axis.
- The output format of the forces and
moments, including the sign convention, is identical to the CBAR
element.
Figure 5. Element Coordinate System and Sign Convention of Element Forces - Diagnostic printouts, checkout runs and non-default setting of search and projection parameters are requested on the SWLDPRM Bulk Data Entry. It is recommended to start with default settings.
- The formats PARTPAT and
ELPAT connect shell element patches on side A and B. The
patches are identified by specifying SHIDA and
SHIDB (for ELPAT connection) and by
specifying property IDs PIDA and PIDB for
PARTPAT connection (wherein SHIDA and
SHIDB are found by appropriate search of best projections of
GS (or GA) onto the surfaces A and B,
respectively). The piercing points GA and GB
are found by appropriate projections onto SHIDA and
SHIDB. Then the axis
GA-GB is used to define four pairs of
auxiliary points GAHi, GBHi, i=1,4 that are
located on patches A and B, respectively. The cross-section area of the resulting
hexahedral is equivalent to the area of the weld. The weld stiffness matrix is first
built using the auxiliary points and then constrained to supporting shell nodes
using respective shape functions.
Figure 6. - Fastener elements are ignored in heat transfer analysis.
- Supported local entries in specific parts can be referenced by the use of "fully-qualified references" on CBAR entries in the model. A fully-qualified reference ("PartName.number") is similar to the format of a numeric reference. "PartName" is the name of the part that contains the referenced local entry (part names are defined on the BEGIN Bulk Data Entry in the model). "number" is the identification number of a referenced local entry in the part "PartName". Refer to Parts and Instances in the User Guide for detailed information on the use of fully-qualified references.
- This card is represented as a rod element in HyperMesh.
