MATVP
Bulk Data Entry Defines material properties for nonlinear creep materials.
| MATVP | MID | CTYPE | A | n | m | B | R | dH | |
| thetaZ |
| MATVP | 2 | STRAIN | 3.28e-11 | 3.15 | -0.2 |
| MID | Unique material identification number.
No default (Integer > 0) |
| CTYPE | Specifies the creep material model
type.
| A | Material parameter. Default = blank (Real > 0.0) |
| n | Material parameter. Default = blank (Real > 0.0) |
| m | Material parameter. Default = blank (-1.0 ≤ Real ≤ 0.0) |
| B | Material parameter. 9 No default (Real > 0.0) |
| R | Universal gas constant. 9 No default (Real > 0.0) |
| dH | Activation energy. 9 No default (Real > 0.0) |
| thetaZ | Absolute zero temperature. Default = 0.0 (Real) |
- CHEXA, CTETRA, CPENTA, CPYRA elements are supported.
- Specifying a MAT1 and a MATVP with the same MID allows modeling creep material. Specifying a MAT1, a MATS1 and a MATVP with the same MID can model a creep material with plasticity.
- You can choose explicit or implicit time integration for creep materials by using the TINT field of the VISCO card.
- The STRAIN hardening formulation
is:
(1) The TIME hardening formulation is:(2) Where,- Equivalent creep strain rate
- Equivalent deviatoric stress
- Total time
The HYPERB hardening form is:(3) Where,- and
- The current and absolute zero temperatures, respectively.
If is set to zero, the temperature dependence is absent.
- The units for
is
.Where,
- Force
- Length
- Time
You might consider switching to another set of units if the value of is too small.
- A VISCO Subcase Entry is mandatory to conduct creep material analysis in a particular subcase.
- If CNTNLSUB is used with the
time hardening form:
- TIMEC indicates the accumulative time, only from the subcases with the VISCO entry.
- TIMET indicates the accumulative time from all the connected subcases.
For example, if there are 4 subcases – Subcase 1, Subcase 2, Subcase 3 and Subcase 5, where only Subcases 1, 3, and 5 are connected by CNTNLSUB.
If Subcases 1 and 5 have VISCO entry while Subcase 3 does not have the VISCO entry, then:- TIMEC will indicate the accumulative time from Subcases 1 and 5 only.
- TIMET will indicate the accumulative time from Subcases 1, 3 and 5.
If CNTNLSUB is not used, then both TIMEC and TIMET have the same effect of denoting the time for a specific subcase (only for subcases with the VISCO entry).
- MATVP is supported for small displacement and large displacement nonlinear analysis.
- The values of B, R and dH are required only when the Hyperbolic Sine hardening form (CTYPE = HYPERB) is used.
