MBSMNTC
Bulk Data Entry Defines a curve scalar moment on two grid points along the specified vector.
MBSMNTC SID G1 G2 CVID G3/Vx Vy Vz
  INT EID
MBSMNTC 3 345 346 2 0 1.0 1.0
  AKIMA 1
SID Load set identification number.
No default (Integer > 0)
G1 Grid point identification number.
G2 Grid point identification number.
CVID Set identification number of the MBCRV entry that provides the load vs. independent variable measured in the coordinate system defined by CID.
(Integer > 0)
G3 Grid point identification number to optionally supply Vx, Vy, and Vz in conjunction with G1.
(Integer >: 0)
Vx X component of vector V
Vy Y component of vector V
Vz Z component of vector V
INT Interpolation type.
AKIMA (Default)
LINEAR
CUBIC
EID Set identification number of the MBVAR for the independent variable expression.
Default = TIME (Integer ≥ 0 or blank)
  1. MBSCMTC applies a scalar action-reaction moment on G1 and G2 along the vector defined by Vx, Vy, and Vz.
  2. The action moment is applied to G1 and the reaction moment is applied to G2.
  3. Right hand rule defines the positive moment.
