NLADAPT
Bulk Data Entry Defines parameters for time-stepping and convergence criteria in Nonlinear Analysis.
NLADAPT | ID | PARAM1 | VALUE1 | PARAM2 | VALUE2 | PARAM3 | VALUE3 | ||
PARAM4 | VALUE4 | PARAM5 | VALUE5 | PARAM6 | VALUE6 |
NLADAPT | 23 | NCUTS | 5 | DTMAX | 4.0 | DTMIN | 1.0 |
ID | Each
NLADAPT Bulk Data Entry should have a
unique ID. No default (Integer > 0) |
NCUTS | Number of cutbacks
allowed to reduce the time increment. Default = 5 (Integer > 0) |
DTMAX | Maximum time increment
allowed. No default (Real > 0.0) |
DTMIN | Minimum time increment
NOPCL | Number of grids
allowed to have open-close contact status change. 2 (Integer ≥ 0) |
NSTSL | Number of grids
allowed to have stick-slip contact status change when the
current time step converged. No default (Integer ≥ 0) |
EXTRA |
DIRECT |
STABILIZ | Scale factor value to
control the stabilization energy limit. 3
- The NLADAPT Bulk Data Entry is selected by the Subcase Information Entry NLADAPT=ID. The NLADAPT Subcase Entry can be specified in any Nonlinear Subcase.
- The following table summarizes the
support of different fields in NLADAPT for different analysis types.
NLADAPT Field Small Displacement Nonlinear Analysis (SMDISP) Large Displacement Nonlinear Analysis (LGDISP) Static Transient Static Transient NCUTS Not Supported Not Supported Supported Supported DTMAX Supported Supported Supported Supported DTMIN Supported Supported Supported Supported NOPCL Supported Supported Supported Supported NSTSL Supported Supported Supported Supported EXTRA Not Supported Not Supported Supported Not Supported DIRECT Supported Supported Supported Supported STABILIZ Not Supported Not Supported Supported Supported - This is a static stabilization based
on viscous damping, where the viscous forces are added to the equilibrium
equations. The viscous damping force
) is:
(1) Where,- f (Scale factor from STABILIZ, Compliance/Strain energy)
- Velocity of the nodes ( ) calculated from the time increment ( ).
