MATUSHT
Bulk Data Entry Defines thermal material properties and parameters for user-defined thermal material.
MATUSHT | MID | PARAM1 | VALUE1 | PARAM2 | VALUE2 | PARAM3 | VALUE3 | ||
PARAM4 | VALUE4 | etc | |||||||
etc | |||||||||
PROPERTY | PROP1 | PROP2 | PROP3 | PROP4 | PROP5 | PROP6 | PROP7 | ||
PROP8 | etc |
MATUSHT | 12 | GROUP | MATHT | USUBID | 5 | NDEPVAR | 1 | ||
PROPERTY | 210.0 | 800.0 | 1700.0 |
Definition
ID | Each MATUSHT Bulk Data Entry should have a
unique ID. No default (Integer > 0) |
USUBID | User subroutine ID. This allows you to define different types
of material properties. Default = Blank (Integer > 0) |
NDEPVAR | User-defined variable. Default = 0 (Integer ≥ 0) |
GROUP | User-defined group specified on the group argument of the
LOADLIB entry. This field is used to
identify the LOADLIB entry to load the
corresponding library (.dll or
.so). (Character String) |
PROPERTY | Indicates that user-defined material property data are to be defined in the subsequent fields. 2 3 4 | |
PROPi | User-defined material property data. 2
3
4 Default = blank (Real) |
- The corresponding dynamic linked libraries (.dll or .so) for the user-defined material is loaded based on the LOADLIB entry. If LOADLIB entry is not defined (or if the GROUP parameter is not specified), then OptiStruct loads the umat.dll or umat.so file from the working directory.
- All parameter and value pairs listed before the PROPERTY continuation line are in free format. Therefore, the pair of parameter name and its value can be located anywhere in the defined fields.
- The PROPi data are directly passed to the loaded .dll or .so file where it used by the subroutine identified by the USUBID parameter.
- MATUSHT is only supported for Heat Transfer Analysis. It can be used to define time-dependent and/or temperature-dependent thermal material properties.
- Shared libraries (.dll or .so) can be created using either Fortran or C for user-defined materials.
