CONV
Bulk Data Entry Defines a free convection boundary condition for heat transfer analysis through connection to a surface element (CHBDYE card).
CONV | EID | PCONID | CNTRLND | TA |
EID | CHBDYE
surface element identification number. No default (Integer > 0) |
PCONID | Convection property
identification number of a PCONV entry. No default (Integer > 0) |
CNTRLND | Control node for time
dependent convection coefficient. Default = 0 (Integer > 0) |
TA | Ambient points used to
specify ambient temperature. No default (Integer > 0) |
- The basic exchange relationship is expressed as:
(1) Where,- Free convection heat transfer coefficient specified on a MAT4 entry, referred by a PCONV entry
- Time-dependent multiplier provided by SPCD, which constrains node identified by CNTRLND field
- Grid temperature
- Ambient temperature
- The time-dependent multiplier ( ) for the heat transfer convection coefficient is controlled via control nodes (CNTRLND field). The same nodes should be referenced on SPCD entries. Time-dependency is activated by referencing the corresponding SPCD entry on TLOAD1/TLOAD2 entries.
- CONV is used with a CHBDYE entry having the same EID.
- In linear steady-state heat transfer analysis, ambient temperature is specified by SPC of the TA point.
- This card is represented as a secondary element in HyperMesh.
