Loading [MathJax]/jax/output/CommonHTML/jax.js
DVMREL1
Bulk Data Entry Linearly relates a design variable to an analysis model material property using the equation: MPi=C0+iCOEFiDVIDi
DVMREL1 ID TYPE MID MPNAME/
FID
    C0
  DVID1 COEF1 DVID2 COEF2 etc.
Example 1
To relate the Damping Coefficient value on a MAT1 card (field 9) to Design Variable 5.
DVMREL1 17 MAT1 22 9     0.0
  5 1.0
Example 2
This example is the same as Example 1, except that it defines MPNAME in place of FID.
DVMREL1 17 MAT1 22 GE     0.0
  5 1.0
Associated Cards
DESVAR 5 GE 1.0 2.0 0.5
MAT1 22 2.1e5   0.3 7.85e-9     1.0
ID Relationship identification number. ID must be unique with respect to other DVMREL1 cards.
No default (Integer > 0)
TYPE Material type to be related (MAT1, MAT2, MAT4, MAT5, MAT8, MAT9, or MAT9OR).
No default (Character)
MID Material identification number.
MPNAME/FID Material property name, such as "E" or "RHO" (as in the documentation of the material Bulk Data Entries), or field number on a material Bulk Data Entry.
No default (Character or Integer > 0)
C0 Constant in relationship equation.
Default = 0.0 (Real)
DVIDi DESVAR ID.
COEFi Coefficient in relationship equation.
Default = 1.0 (Real)
  1. See the DVMREL - Types section for details on the supported material fields and the MPNAME/FID entries.
