DSHAPE
Bulk Data Entry Defines parameters for classic and grid-based free-shape design variables.
Format 1 (Classic)
| DSHAPE | ID | TYPE | |||||||
| PERT | DTYPE | MVFACTOR | NSMOOTH | MXSHRK | MXGROW | SMETHOD | NTRANS | ||
| GRID | GMETH | GSETID1/
GID1 |
GID2/ GSETID2 |
GID3/ GSETID3 |
GID4/ GSETID4 |
GID5/ GSETID5 |
GID6/ GSETID6 |
| GID7/ GSETID7 |
GID8/ GSETID8 |
etc | etc | ||||||
| PATRN | TYP | AID/ XA |
YA | ZA | FID/ XF |
YF | ZF | ||
| DRAW | DTYP | DAID/ XDA |
YDA | ZDA | DFID/ XDF |
YDF | ZDF | ||
| DRAFT | |||||||||
| EXTR | ECID | XE | YE | ZE | |||||
| GRIDCON | GCMETH | GCSETID1 /
GDID1 |
CTYPE1 | CID1 | X1 | Y1 | Z1 | ||
| GCMETH | GCSETID2 /
GDID2 |
CTYPE2 | CID2 | X2 | Y2 | Z2 | |||
| etc | etc | ||||||||
| SDCON | SDCID1 | XL1 | XU1 | YL1 | YU1 | ZL1 | ZU1 | ||
| SDCID2 | XL2 | XU2 | YL2 | YU2 | ZL2 | ZU2 | |||
| BMESH | BMID | ||||||||
| FSSPLIT | SPLIT |
Format 2 (Grid-based)
| GRID | GMETH | ID1 | ID2 | ID3 | ID4 | ID5 | ID6 | ||
| ID7 | ID8 | etc | etc | ||||||
| BOUND | TOTAL/MESHF | LB | UB | ||||||
| FILTER | FTYPE | RADIUS | |||||||
| BOUNDARY | BTYPE/SETID | SKIP | |||||||
| GRIDCON | GCMETH | GCSETID1 | CTYPE2 | CID1 | X1 | Y1 | Z1 | ||
| etc | GCMETH | GCSETID2 | CTYPE2 | CID2 | X2 | Y2 | Z2 | ||
| SMOOTH | METHOD | NLAYER | TRANS |
| ID | Each
DSHAPE card must have a unique ID. No default (Integer > 0) |
| TYPE | Free-shape optimization
type.
| PERT | Indicates perturbation information is to follow. | |
| DTYPE | Direction type for the free-shape variation.
| MVFACTOR | Initial limit on the
movement factor of the design grids. The unit of
MVFACTOR is the average mesh size of meshes
adjacent to grids defined after GRID. Only the initial value of this limit can be set. The values in subsequent optimization iterations are automatically adjusted to enhance to enhance iterative stability and convergence speed; however, they will never be greater than the initial limit. Default = 0.5 (Real > 0.0) |
| NSMOOTH | Number of grids layers
NSMOOTH. Default = 10 (Integer) |
| MXSHRK | Maximum shrinking
distance. No default |
| MXGROW | Maximum growing
| SMETHOD | Mesh smoothing
method. Method 1 is faster than method 2, but method 2 is more robust in avoiding mesh distortion. Default = 1 (1 or 2) |
| NTRANS | Number of design grid
layers in the transition zone to non-design area, where additional
treatment will be applied to produce smooth transition. 2 Default = 0 (Integer ≥ 0) |
| GRID | Indicates that a list of grid IDs or grid sets is to follow (depending on the value of the GMETH field). These grids are design variables for the free-shape optimization. | |
| GMETH | Classic: Field
indicating whether grids are to be defined by:
Grid-based: Field indicating whether grids are to be defined by:
| GID# | Grid identification
numbers. List of grids for which this DSHAPE card
is defined (only valid if GMETH field is set to
ID). No default (Integer > 0) |
| GSETID# | Grid SET identification
number. A grid set containing design grids for free-shape
optimization (only valid if GMETH field is set to
SET). No default (Integer > 0) |
| ID# | Identification numbers.
List of identification numbers that depend on the value of the
GMETH field in grid-based free-shape
optimization. No default (Integer > 0) |
| PATRN | Indicates that variable pattern grouping is active. Indicates that information about the pattern group will follow. | |
| TYP | Type of variable pattern
grouping. Required if any symmetry or variable pattern grouping is
desired. Only 1-plane symmetry
(TYP=10) is currently
supported. Default = 0 (0 or 10) |
| AID/XA, YA, ZA | Variable pattern grouping
anchor point. These fields define a point that determines how grids
are grouped into variables. 1 The X, Y, and Z values are in the global
coordinate system. You may put a grid ID in the
AID/XA field to define the
anchor point. Default = origin (Real in all three fields or Integer in AID/XA field) |
| FID/XF, YF, ZF | Direction of first vector
for variable pattern grouping. These fields define an xyz vector
which determines how grids are grouped into variables. 1 The X, Y, and Z values are in the global
coordinate system. If FID is defined, it defines a vector pointing from grid AID or point (XA, YA, and ZA) to grid FID. If XF, YF, ZF are defined, it defines a vector pointing from point (XA, YA, and ZA) to point (XA+XF,YA+YF,ZA+ZF). (XA, YA, and ZA) are coordinates of the anchor point defined by AID or XA, YA, and ZA. If all fields are blank and the TYP field is not blank or zero, OptiStruct gives an error. No default |
| DRAW | Indicates that casting constraints are being applied. Indicates that draw direction information is to follow. Only valid for design grids on solid elements. | |
| DTYP | Draw direction constraint
type.
| DAID/XDA, YDA, ZDA | Draw direction anchor
point. These fields define the anchor point for draw direction of
the casting. The point may be defined by entering a grid ID in the
DAID field or by entering X, Y, and Z
coordinates in the XDA, YDA,
and ZDA fields, these coordinates will be in the
basic coordinate system. Default = origin (Real in all three fields or Integer in first field) |
| DFID/XDF, YDF, ZDF | Direction of vector for
draw direction definition. These fields define a point. The vector
goes from the anchor point to this point. The point may be defined
by entering a grid ID in the DFID field or by
entering X, Y, and Z coordinates in the XDF,
YDF, and ZDF fields, these
coordinates will be in the basic coordinate system. No default (Real in all three fields or Integer in first field) |
| DRAFT | Draft angle in
degrees. Default = 0.0 (0.0 ≤ Real < 90.0) |
| SDCON# | Indicates that side constraints are being applied. | |
| SDCID# | The ID of a coordinate system which the following XL#, XU#, YL#, YU#, ZL#, or ZU# components are resolved in. | |
| XL#, XU#, YL#, YU#, ZL#, ZU# | Side constraints defined by lower and upper bounds of coordinates, which restrict the moving space of the design grids. Any of the six fields could be blank, which means the corresponding coordinate is not constrained. | |
| EXTR | Indicates that extrusion constraints are being applied. Indicates that extrusion information is to follow. Only valid for design grids on solid elements. | |
| ECID | The ID of a coordinate
system which the following X, Y, and Z components are resolved
in. For Free-Shape 9.0, only consider two simple extrusion
paths:
Default = 0 (Integer > 0) |
| XE, YE, ZE | When ECID is a rectangular system ID, X, Y, and Z are components of a vector under system EID, which define the extrusion path. | |
| GRIDCON | Indicates that a list of
grids with associated constraints are to follow. Note: Grids within the smoothing zone (defined by
NSMOOTH) will move during Free-shape
optimization to avoid mesh distortion without changing the shape
of the model. You can also constrain the movement of these grids
by GRIDCON even if they are not defined after
GRID.
| GCMETH | Indicates that a list of
grids is to be defined by:
| GCSETID# | Grid SET identification
numbers. IDs of certain grid SETs which are constrained to move in a
predefined manner. No default (Integer > 0) |
| GDID# | IDs of certain grids which
are constrained to move in a predefined manner. No default (Integer > 0, ID must also be present in the list following the GRID flag) |
| CTYPE# | Constraint type applied to
the grid GDID#.
No default |
in. Default = 0 (Integer ≥ 0) |
| X#, Y#, Z# | X, Y, and Z components of
a vector, which either defines the direction in which the grid
GDID# is constrained to move, or the normal
of a plane on which the grid GDID# is constrained
to remain. Default = 0.0 (Real) |
| BMESH | Indicates that a BMFACE ID is to follow. | |
| BMID | The BMFACE ID which defines a list of QUADs and/or TRIAs which define a barrier that the design surface will not penetrate during shape optimization. | |
| FSSPLIT | Indicates that the design grids in the Free-Shape design space referenced by DSHAPE are split into multiple DSHAPE's, based on their normal orientation. | |
| SPLIT | Controls the splitting of
the design grids for this DSHAPE entry.
| BOUND | Indicates that shape variable bounds are to follow. | |
| TOTAL/MESHF | Character flag indicating
the bound setting way.
No default |
| LB | Shape design variable
lower bound. Default value = -5.0* average mesh size When TOTAL is specified, (Blank, Real ≤ 0.0) When MESHF is specified, (Blank, Real ≥ 0.0) |
| UB | Shape design variable
upper bound. Default value = 5.0* average mesh size (Blank, Real ≥ 0.0) |
| FILTER | Indicates that nodal shape sensitivities filtering options are to follow. 6 | |
| FTYPE | Filtering type of nodal
shape sensitivities. It indicates the method of nodal shape
sensitivities smoothing.
| RADIUS | Sensitivities filtering
radius. It requires a reasonable value based on average mesh size of
design domain. It is recommended that the filter radius is not too
small compared to the average mesh size or too large compared to the
whole design domain. 5 Default = 4* average mesh size (Real > 0.0) |
| BOUNDARY | Indicates that the boundary information of design domain is to follow. | |
| BTYPE | Boundary handling type for
shell design domain.
| SETID | Grid SET identification
number, which contains a set of non-design grids. No default (Blank or Integer > 0) |
| SKIP | Boundary skip. This
parameter tells OptiStruct to skip
certain nodes out of the design domain.
| SMOOTH | Flag to indicate that the parameters for mesh smoothing method are to follow. | |
| METHOD | Mesh smoothing method.
| NLAYER | Number of grid layers for
mesh smoothing.
Default = 10 (Integer > 0 or ALL) |
| TRANS | Flag to indicate a
transition zone to the non-design region.
Classic:
- For a single plane of symmetry (TYP = 10), the plane is defined normal to the first vector and is located at the anchor node.
- The NTRANS option allows
you to achieve a smooth transition between design and non-design regions. This
additional smoothness; however, comes with an inherent cost of a reduction in
design flexibility. NTRANS improves design smoothness across
the transition zone between design and non-design regions at the expense of
design flexibility.
For detailed information illustrating the working mechanism of NTRANS, refer to Define Free-shape Design Regions in the User Guide.
- The draft angle can be specified in degrees
via the DRAFT field, as illustrated in Figure 1. Geometric constraints
(GRIDCON and SDCON) may not be
satisfied when the draft angle is activated:
Figure 1. Grid-based Free Shape Optimization - It is required to define the nodes on the surface, as well as the nodes in the interior region as design nodes.
- RADIUS is sensitivities filtering radius. For a given design node, the solver only considers its surrounding design nodes, which the distance to this given node is within RADIUS, for sensitivities filtering. RADIUS is quite significant to the final shape design. The shape change is drastic when RADIUS is small. As a consequence, the model has higher local shape changes.
- For a given design node, its smoothed
sensitivity is (
), Where,Filtering factor is calculated based on FTYPE, Figure 2 shows the filter factor curves for each FTYPE. Generally filtering factor at this given node is 1.0, since it is at the center, and the node outside RADIUS has zero filtering factor.
- Filtering factor at node #i
- Sensitivity at node #i
Figure 2. - For multiple disconnected design patches, it is recommended to define separate DSHAPE for each disconnected patch; however, it is not recommended to define multiple DSHAPE cards for connected design domains.
- LB and UB in BOUND continuation line are applied to each design variable, not the total magnitude of a design grid, that means the total magnitude may be beyond bounds.
- When the design domain has finer mesh and more design nodes, the optimization would take more computation time.
- This card is represented as an optimization design variables in HyperMesh.
