MBMNTC
Bulk Data Entry Defines a curve moment at a grid point by specifying a vector.
MBMNTC | SID | G1 | CID | CVID | G3/N1 | N2 | N3 | G2 | |
INT | EID |
MBMNTC | 3 | 345 | 4 | 0.0 | 1.0 | 0.0 | |||
AKIMA | 42 |
SID | Load set identification number. No default (Integer > 0) |
G1 | Grid point identification number where
the action force is applied. No default (Integer > 0) |
CID | Coordinate system identification number.
Blank or 0 infer the basic coordinate system. Default = 0 (Integer ≥ 0, or blank) |
CVID | Set identification number of the
MBCRV entry that gives the load vs. independent variable
measured in the coordinate system defined by CID. (Integer > 0) |
G3 | Grid point identification number to
optionally supply N1, N2,
N3 in conjunction with G1. (Integer > 0) |
N1,N2,N3 | Defines the direction of the force
vector. At least one of the vector components must be non-zero. Default = 0.0 (Real) |
G2 | Grid point identification number where
the reaction force is applied. If blank or zero, then the force is an action-only
force. Default = 0 (Integer ≥ 0) |
INT | Interpolation type.
(Character) |
EID | Set identification number of the MBVAR for the independent variable
expression. Default = TIME (Integer ≥ 0 or blank) |
- This card is represented as a moment load in HyperMesh.
