FATMCRV
Bulk Data Entry Specifies the corresponding quantities (Ti) vs SN curve table ID’s via TABLEXN entries (TIDi).
FATMCRV TID QTYPE TYPE
  T1 TID1 T2 TID2 T3 etc
FATMCRV 101 SM SN
  150.0 10 175.0 20 ENDT
TID Table identification number.
(Integer > 0)
QTYPE Weld type.
SM
Identifies that the corresponding Ti values are Mean Stress values at which the Fatigue curves are defined.
No default
TYPE Fatigue analysis type.
SN
Stress-Life Fatigue, the TID tables identify SN curves for Fatigue analysis.
No default
Ti Quantity values of the type defined via the QTYPE field.
No default (Real)
TIDi Table identification numbers of TABLEXN entries which identify the Fatigue curves. The nature of the Fatigue curves is defined via the TYPE field.
No default (Integer > 0)
  1. TIDi must be unique with respect to all FATMCRV and TABLEXN table identification numbers.
  2. Quantity values must be listed in ascending order.
  3. The end of the table is indicated by the existence of ENDT in either of the two fields following the last entry. An error is detected if any continuations follow the entry containing the end-of-table flag ENDT.
  4. This table can be referenced by the MCRV_ID field of the MATFAT entry.
