SPCOFF
Bulk Data Entry Defines degrees-of-freedom to be excluded from AUTOSPC.
SPCOFF | G1 | C1 | G2 | C2 | G3 | C3 | G4 | C4 |
SPCOFF | 13 | 234 | 14 | 5 |
Definition
Gi | Grid or scalar point identification number. (Integer > 0) |
C | Component numbers. (Integer zero or blank for scalar points, or up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks for grid points). |
- Degrees-of-freedom on this entry will be excluded from AUTOSPC.
- If both SPC and SPCOFF are defined for the same degree-of-freedom, then SPC takes priority
