BEGIN
Bulk Data Entry Indicates the beginning of data that is used to describe a specific entity (or entities) for inclusion in a model. The BEGIN entry is used in conjunction with the END entry to define the data required for a specific entity.
BEGIN | TYPE | NAME/SEID |
BEGIN | FEMODEL | Bumper |
BEGIN | HYPRBEAM | Square |
BEGIN | SUPER | SEID |
TYPE | Specifies the entity type
that will be defined by the BEGIN Bulk Data Entry.
NAME | This field specifies the
name of the entity that is defined by the BEGIN
entry. The name of the included part should be specified in the NAME field. (Character String) |
SEID | Partitioned superelement
identification number. This entry is valid only when TYPE = SUPER. No default (Integer > 0) |
- The BEGIN and END Bulk Data Entries are used in conjunction to define an entity within the full model.
- The INCLUDE entry, similar to almost any other Bulk Data Entry, is allowed between BEGIN and END entries. However, BEGIN and END should exist in the same file.
- Models are often defined in separate files, and the block (BEGIN - END) contains only INCLUDE entries. It is possible to duplicate a single part by including the same file(s) in different BEGIN-END blocks.
- In case of partitioned (PART) superelement (TYPE = SUPER), the Bulk Data Section can be divided into separate sections for each PART. This division is accomplished by using the BEGIN SUPER entry. These separate sections of the bulk data are self-contained and each section contains all geometry, elements, properties, constraints and loading data for that component of the model. Note that there is no entry to mark the ending of a superelement.
- There can be multiple sections of arbitrary beam data; one for each beam section.
- An example set of data for the definition of
an arbitrary beam section is as
follows:
BEGIN,HYPRBEAM,SQUARE $ GRIDS,1,0.0,0.0 GRIDS,2,1.0,0.0 GRIDS,3,1.0,1.0 GRIDS,4,0.0,1.0 $ CSEC2,10,100,1,2 CSEC2,20,100,2,3 CSEC2,30,100,3,4 CSEC2,40,100,4,1 $ PSEC,100,1000,0.1 $ END,HYPRBEAM
