ASET
Bulk Data Entry Defines the boundary degrees-of-freedom of a superelement assembly for matrix reduction.
ASET | G1 | C1 | G2 | C2 | G3 | C3 | G4 | C4 |
ASET | 564 | 4 | 765 | 4561 | 8 | 5 |
Gi | Grid or scalar point
identification numbers. No default (Integer > 0) |
Ci | Component
numbers. (Integer zero or blank for scalar points, or up to 6 unique digits (0 < integer ≤ 6) may be placed in the field with no embedded blanks for grid points. The components refer to the coordinate system referenced by the grid points.) |
- Refer to Direct Matrix Input in the User Guide for more information on the use of this card.
- A fatal error will be issued if the input contains ASET or ASET1, but PARAM,EXTOUT is not given.
- When the SPSYNTAX setting on the SYSSETTING I/O Option is set to CHECK (default) or STRICT, it is required for grid/component pairs (G#/C#) that the component be 0 or blank when the grid reference is a scalar point (SPOINT), and that the component be > 1 when the grid reference is a structural grid point (GRID). When SPSYNTAX is set to MIXED, it is allowed for grid/component pairs (G#/C#) that the grid reference be either a scalar point (SPOINT) or a structural grid point (GRID) when the component is 0, 1 or blank; interpreting all of these as 0 for scalar points and as 1 for structural grids. When the component is greater than 1, the grid reference must always be a structural grid (GRID).
- This card is represented as a constraint load in HyperMesh.
