SECTION
Bulk Data Entry Defines a specific face of a cross-section of the model.
The section is determined through a set of Grid points and the face is specified by a set of elements. The face is interpreted as the side of the Grid point set not containing the specified elements.
SECTION SID LABEL GSID ESID RSID CID GID STYPE
SID Set identification number of the section.
No default (Integer)
LABEL The section name associated with the defined section.
No default (Character string)
GSID Set identification number of a SET of GRID points that defines the geometry of the section. 2
No default (Integer > 0)
ESID Set identification number of a SET of elements (TYPE=ELEM) that defines the face of the section. 2
RSID Set identification number of a SET of rigid elements (TYPE=RIGID) that defines the face of the section. 2
CID Coordinate system identification number of the coordinate system into which the forces and moments are resolved. 7
LOCAL (Default)
Indicates that a LOCAL coordinate system will be established automatically for the section chosen and use it for the output. The X-axis is normal to the section and the Y-axis comes from the projection of the basic Y-axis onto the section.
(LOCAL or Integer ≥ 0)
GID Grid point identification number of the grid about which the moments are calculated.
CENT
Indicates that the coordinate system is shifted to the centroid of the section.
PRIN
Indicates that the coordinate system should also be rotated to the principal axes.
ORIGIN
Indicates that the reference point is the original of coordinate system of section (CID).
Integer > 0
Grid point identification number about which the moments are calculated.
Default = <Geometric Centroid of the Section>
STYPE Identifies the type of section that is generated using this entry.
RESULT
Defines a face of the cross-section on which the forces/moments are calculated as a response in analysis and optimization runs (RESFORCE response). 1
FLOW
Defines a face of the cross-section which is used for Power flow and Mechanical intensity calculations. 1
PROP
Indicates that this section is only to be used for Section property analysis and optimization via RTYPE=SECTION on DRESP1.
blank (Default)
  1. The SECTION entry can be used to define a face of the cross-section on which the forces/moments are calculated as a response in analysis and optimization runs via RTYPE=RESFORCE (on the DRESP1 entry). In such cases, Grid Point Forces or Moments are added at each GRID specified within the grid set (GSID). The effect of all elements on the grid points (GSID) is considered in the calculation of the response except the elements specified via ESID. The SECTION entry can also be used for Power flow and Mechanical intensity calculations. For more information regarding Power flow calculations, refer to the POWERFLOW I/O Options Entry. For the Power flow and mechanical intensity calculations, only the GSID, ESID, and STYPE fields are required. The other fields are ignored if input.
  2. The section is determined through a set of grid points and the particular face is specified by a set of elements. The face is interpreted as the side of the grid point set NOT containing the specified elements (Figure 1 through Figure 3). This is similarly applicable to RSID (rigid element set).
    section_resforce
    Figure 1. Defining the SECTION for the RESFORCE Response
    section_gsid
    Figure 2. Selecting the GSID Set
    section_esid
    Figure 3. Selecting the Corresponding ESID
  3. The default GID is the geometric center of the cross-section. For example, in a shell model, if the cross-section is tapered (Figure 4), the geometric center is automatically updated (if the GID field is blank).
    Figure 4. Geometric Center via GID=Default
  4. For Section property, if coordinate system is defined, then the properties are calculated in the defined system. If no coordinate system is defined, the basic system is used.
  5. For Section property, currently only beam, bar, shells and solid elements are supported. Offsets are taken into account, and Shear center is currently not calculated.
  6. SECTION is automatically created for solid pretension bolt section. For this case, CID is LOCAL and GID is CENT.
  7. In cases when the local coordinate system from LOCAL cannot be uniquely determined, a warning will be printed. In such cases, it is recommended to use a user-defined coordinate system. The X-axis of this user-defined coordinate system must be normal to the cross-section.
  8. This feature is supported for analysis, as well as optimization.
