DSCREEN
Bulk Data Entry Defines design response screening data.
Refer to Constraint Screening in the User Guide for information regarding screening responses for design constraints.
DSCREEN | RTYPE | THOLD | MAXC |
Alternate Format
DSCREEN | AUTO | LEVEL | BUCK |
DSCREEN | STRESS | -0.6 | 4 |
Associated Cards
DRESP1 | 98 | SS11 | STRESS | PSHELL | 1 | 7 | 1 | ||
DRESP1 | 99 | SS11 | STRESS | PSHELL | 2 | 7 | 3 | ||
DRESP1 | 100 | SS11 | STRESS | PSHELL | 2 | 7 | 5 |
RTYPE | Response type affected by
the response screening settings on this definition. No default (Character) 1 |
THOLD | Normalized threshold value
- constraint/objective will not be retained during the current
iteration if its normalized value is below THOLD.
4
5 Default = -0.5 (Real < 0.0) |
MAXC | Maximum number of
constraints/objectives to be retained for each region definition and
each load case. 5 Default = 20 (Integer > 0) |
AUTO | Automatic adjustment of
screening criteria. When this is activated, the screening algorithm will seek to retain the least number of responses that are necessary for stable convergence. Automatic response screening is active by default. It is disabled by the presence of any DSCREEN definition in the input data. Default = AUTO (AUTO or blank) |
LEVEL | The automatic response
screening has levels 1 through 5, with 1 being the least aggressive
(more responses retained) and 5 being the most aggressive (less
responses retained).
Default = 3 or ON (1, 2, 3, 4, 5, ON, or OFF) |
BUCK | Controls the activation
and deactivation of automatic screening adjustments for buckling
eigenvalues in optimization.
For detailed information, refer to the DSCREEN section of Constraint Screening in the User Guide. |
- RTYPE may be any of the RTYPEs allowed on the DRESP1 entry, or EQUA or EXTERNAL or AUTO.
- RTYPE EQUA refers to DRESP2 definitions. If DRESP2 definitions are given the same region identifier, they should reference similar equations.
- RTYPE EXTERNAL refers to DRESP3 definitions. If DRESP3 definitions are given the same region identifier, they should reference similar equations.
is the normalized response
(with regard to a particular constraint). If
> THOLD, the response (referenced on
the DCONSTR entry) will be retained for this constrain
definition.
is calculated with respect to the upper (
) and lower (
) bounds of the response on this constraint,
as:
(1) (2) If the response values are initially lower than the upper bounds and move closer towards their upper bounds, they have a higher chance of being retained. All response values above the upper bounds are retained. Similarly, if response values initially higher than the lower bounds move closer towards their lower bounds, the chances of them being retained is higher. All response values below the lower bounds are retained.
Where, is the normalized response (with regard to a particular objective). If > THOLD, the response ( on the DOBJREF entry) will be retained for this objective definition. is calculated with respect to the reference values ( on DOBJREF entry) for the corresponding MINMAX or MAXMIN implementations of the objective, as:(3) (4) Depending upon the type of objective (MINMAX or MAXMIN) selected, the chances of a response being retained varies.
- When no DSCREEN
definitions are present in the input data, automatic constraint screening is
active for all responses. The presence of any DSCREEN
definition disables the automatic screening for all response types.Note: The THOLD and MAXC defaults do not apply for MASS, MASSFRAC, VOLUME, VOLUMEFRAC, or FREQ responses. The screening thresholds for these responses are set to be very high, by default and they are retained for stability purposes. Hence, constraint screening does not influence these responses and the same will be applied even if auto-screening is activated.
- With automatic screening, the upper bound on the EIGRL card for buckling analysis will be adjusted in order to calculate only the necessary buckling eigenvalues (responses) that are potentially retained in the optimization.
- This card is represented as an optidscreens in HyperMesh.
