TABLEST
Bulk Data Entry Specifies the material property tables for elasto-plastic, temperature-dependent materials.
| TABLEST | TID | ||||||||
| T1 | TID1 | T2 | TID2 | T3 | etc. |
| TABLEST | 101 | ||||||||
| 150.0 | 10 | 175.0 | 20 | ENDT |
| TID | Table identification
number. (Integer > 0) |
| Ti | Temperature values. Must
be listed in ascending order. (Real) |
| TIDi | Table identification
numbers of TABLES1 entries. (Integer > 0) |
- TIDi must be unique with respect to all TABLES1 and TABLEST table identification numbers.
- The end of the table is indicated by the existence of ENDT in either of the two fields following the last entry. An error is detected if any continuations follow the entry containing the end-of-table flag ENDT.
- This table is referenced by MATS1 entries that define elasto-plastic (TYPE=PLASTIC) materials.
