MBMNT
Bulk Data Entry Defines a constant moment at a grid point by specifying a vector.
MBMNT | SID | G1 | CID | M | G3/N1 | N2 | N3 | G2 |
MBMNT | 3 | 345 | 100.0 | 0.0 | 1.0 | 0.0 |
SID | Load set identification number. No default (Integer > 0) |
G1 | Grid point identification number where
the action force is applied. No default (Integer > 0) |
CID | Coordinate system identification number.
Blank or 0 infer the basic coordinate system. Default = 0 (Integer ≥ 0, or blank) |
M | Moment magnitude. No default (Real) |
G3 | Grid point identification number to
optionally supply N1, N2,
N3 in conjunction with G1. (Integer > 0) |
N1,N2,N3 | Defines the direction of the force
vector. At least one of the vector components must be non-zero. Default = 0.0 (Real) |
G2 | Grid point identification number where
the reaction force is applied. If blank or zero, the force is an action-only
force. Default = 0 (Integer ≥ 0) |
- This card is represented as a moment load in HyperMesh.
