MOTNJC
Bulk Data Entry Defines a joint motion vs. time by specifying a curve.
MOTNJC SID JID MTYPE CVID INT EID DTYPE
  D0 V0
MOTNJC 3 345 ROT 2 AKIMA 99
SID Load set identification number.
(Integer > 0)
JID Grid point identification number.
(Integer > 0)
MTYPE TRANS or ROT, ignored for revolute and translational joints.
CVID Set identification number of the MBCRV entry that gives the motion vs. time.
(Integer > 0)
INT Interpolation type.
LINEAR
CUBIC
AKIMA (Default)
(Character)
EID Set identification number of the MBVAR for the independent variable expression.
Default = TIME (Integer ≥ 0 or blank)
DTYPE Motion data type.
DIS
VEL
ACC
blank
Means displacement motion.
D0 Initial displacement, if motion data is of type velocity or acceleration, ignored otherwise.
V0 Initial velocity, if motion data type is acceleration, ignored otherwise.
  1. Joint motion can only be applied to cylindrical joints (MTYPE = TRANS or ROT), revolute joints (MTYPE = ROT), and translational joints (MTYPE = TRANS).
  2. The MOTNJC Bulk Data Entry should be selected in the MOTION Subcase Information section, if it is to be included in the analysis.
