CBEAM
Bulk Data Entry Defines a beam element (BEAM) of the structural model.
| CBEAM | EID | PID | GA | GB | X1/G0 | X2 | X3 | OFFT | |
| PA | PB | W1A | W2A | W3A | W1B | W2B | W3B |
| CBEAM | 2 | 39 | 7 | 3 | 13 | ||||
| 513 | 3.0 |
| EID | Unique element
| PID | PBEAM or PBEAML property entry
Default = EID (Integer > 0 or <String>) |
| GA,GB | Grid point identification
numbers of connection points. No default (Integer > 0; GA ≠ GB) |
| X1,X2,X3 | Components of vector v, at
end A, measured at the offset point for end A, parallel to the
components of the displacement coordinate system for
GA, or the basic coordinate system, to
determine (with the vector from offset end A to offset end B) the
orientation of the element coordinate system for the beam element.
4 No default (Real) 2 |
| G0 | Grid point identification
number to optionally supply X1,
X2, X3. Direction of
orientation vector is GA to
G0. No default (Integer > 0) 2 |
| OFFT | Character string
specifying the interpretation of the offset vector specification.
4 Default = GGG (Character or blank) |
| PA, PB | Pin flags for beam ends A
and B, respectively. Used to remove connections between the grid
point and selected degrees-of-freedom of the beam. The
degrees-of-freedom are defined in the element's coordinate system
and the pin flags are applied at the offset ends of the beam. The
beam must have stiffness associated with the PA
and PB degrees-of-freedom to be released by the
pin flags. For example, if PA=4,
the PBEAM entry must have a
non-zero value for J, the torsion stiffness.
3 No default (Integer > 0; up to 5 of the unique digits 1-6 with no embedded blanks) |
| W1A,W2A,W3A, W1B,W2B,W3B | Components of offset
vectors, measured in the displacement coordinate systems at grid
points A and B or in the element coordinate system, from the grid
points to the end points of the axis of shear center. 4 Default = blank (Real or blank) |
Figure 1. Beam Element Coordinate System
Figure 2. Direction of Internal Forces and Moments (for CBEAM entry)
- If X1/G0 is a positive integer and X2 and X3 are blank, then G0 is used to orient the element, otherwise X1, X2, X3 is used.
- G0 ≠ GA or GB.
- If there are no pin flags or offsets the continuation may be omitted.
The OFFT character string specifies how the offset and orientation vector components are computed. By default, the offset vectors are specified in the Global (local displacement) coordinate system of each grid A and B, and the orientation vector is specified in the Global coordinate system of grid A. Using the codes below, the offset vector can be specified in the element coordinate system and the orientation vector can be specified in the basic coordinate system. The valid character strings and their meanings are:The element system x-axis is defined from GA to GB. The orientation vector and the element system x-axis are then used to define the z and y axes of the element system. A vector is formed from the cross product of a vector going from Grid A to Grid B and the orientation vector to create the element coordinate z-direction.
OFFT Orientation Vector End A Offset End B Offset GGG Global Global Global BGG Basic Global Global GGO Global Global Element BGO Basic Global Element GOG Global Element Global BOG Basic Element Global GOO Global Element Element BOO Basic Element Element - Offset vectors are treated like rigid elements. The length of the offset vectors is not affected by thermal loads.
- Torsional stiffness due to warping of the cross-section is not considered.
- String based labels allow for easier visual identification of properties, when being referenced by the elements cards. For more details, refer to String Label Based Input File in the Bulk Data Input File.
- In the ASCII
.force file below, the SHEAR-1 and BENDING-1 values are
associated with Plane-1, while SHEAR-2 and BENDING-2 values are associated with
Plane-2 in Figure 1.
ITER 0 1 1 1 LOAD: 2 (LOAD) Transverse_Load BAR #-END AXIAL SHEAR-1 SHEAR-2 TORQUE BENDING-1 BENDING-2 1-A 0.000E+00 0.000E+00 -2.5000E+02 0.000E+00 0.000E+00 -2.5000E+04 1-B 0.000E+00 0.000E+00 -2.5000E+02 0.000E+00 0.000E+00 1.4552E-11 - This card is represented as a bar2 element in HyperMesh.
