CACINF3
Bulk Data Entry Defines an Acoustic Infinite Element with a triangular base.
CACINF3 | EID | PID | G1 | G2 | G3 |
CACINF3 | 7 | 1 | 123 | 225 | 9991 |
EID | Unique element
PID | Identification number of a
PACINF property entry. No default (Integer > 0) |
G1, G2, G3 | Grid point identification
numbers of element base connection points. No default (Integer > 0) |
- The element should be connected to acoustic grid points.
- The element normal is defined by the right-hand rule. If the normal does not point to the exterior domain, an error message will be issued.
