SEBULK
Bulk Data Entry Defines superelement boundary search options and the type of superelement.
SEBULK | SEID | TYPE | RSEID | METHOD | TOL | LOC | UNITNO |
SEBULK | 1001 | REPEAT | 1002 | MANUAL | 1.0E-4 | YES |
Definition
SEID | Identification number of the partitioned superelement. No default (Integer ≥ 0) 5 |
TYPE | Superelement type:
No default (Character) |
RSEID | Identification number of the reference superelement. This is applicable only when TYPE = REPEAT. Default = 0 (Integer ≥ 0) |
METHOD | Method used for searching the boundary grid points.
TOL | Search tolerance for the boundary grid points. Default ≥ 0 (Real 0.0) |
LOC | Coincident location check option. This is applicable when
METHOD = MANUAL.
(Character) |
UNITNO | Fortran unit number for OUTPUT4
file (specified through ASSIGN,INPUTT4). This is applicable only when TYPE = EXTOP4. No default (Integer > 0) |
- This specification must be specified in the MAIN Bulk Data and is meaningful only if part superelements (using BEGIN SUPER).
- A superelement with TYPE = PRIMARY, may itself be repositioned using an SELOC entry. In this case, the primary superelement will be positioned at the location implied by the SELOC entry.
- The following comments apply to
TYPE= REPEAT.
- An SEID whose TYPE is REPEAT is referred to as a secondary superelement. The RSEID specified in this case is regarded as the primary superelement.
- The primary superelement must be either a part superelement or an external superelement created by another earlier job. It must be defined via its own SEBULK entry, wherein TYPE must be either "PRIMARY".
- The primary superelement does not include superelements upstream of the primary superelement.
- The primary superelement may be re-positioned (2).
- If the primary superelement specified by RSEID is a part superelement, then the secondary superelement is a copy of the primary superelement. In this case, the boundary, loads, constraints and reduction procedure of the secondary superelement can be different from those of its primary superelement.
- The secondary superelement in this case may or may not reference an SELOC entry.
- If it references an SELOC entry, then an identical copy of its primary superelement will be positioned at the location implied by the SELOC entry.
- SECONCT can be used to augment the search procedure and/or to override the global tolerance. TOL and LOC are the default values that can be modified between two superelements by providing the required tolerance on the SECONCT entry.
- A SEID=0 is valid for the residual part only if it is desired to set a TOL value for the residual.
