MBSFRCC
Bulk Data Entry Defines a curve scalar load on two grid points.
MBSFRCC SID G1 G2 CVID INT EID
MBSFRCC 3 345 346 1 AKIMA 1
SID Load set identification number.
No default (Integer > 0)
G1 Grid point identification number.
G2 Grid point identification number.
CVID Set identification number of the MBCRV entry that gives the load vs. independent variable measured in the coordinate system defined by CID.
(Integer > 0)
INT Interpolation type.
AKIMA (Default)
CUBIC
LINEAR
(Character)
EID Set identification number of the MBVAR for the independent variable expression.
Default = TIME (Integer ≥ 0 or blank)
  1. MBSFRCC applies a translational action-reaction force along the line of action defined by the line segment connecting G1 and G2.
  2. The action force is applied to G1 and the reaction force is applied to G2.
  3. Tensile force is positive.
