LATPRM
Bulk Data Entry Defines the parameters available for Lattice Optimization Control.
LATPRM PARAM1 VAL1 PARAM2 VAL2 PARAM3 VAL3 PARAM4 VAL4
  PARAM5 VAL5 etc
LATPRM LATLB CHECK POROSITY MED
PARAMi Parameter name. See below for valid names.
VALi Parameter value.
(Real, Integer, or Character)
  1. Some of the parameters may also be defined as separate entities in the I/O section of the deck, using the Previous (OS3.5) Input Format. Only one definition is allowed.
  2. This card is represented as an opticontrols in HyperMesh.
  3. For more information, refer to Lattice Structure Optimization in the User Guide.
