LATPRM, BUCKSF
Bulk Data Entry Controls the value of the Buckling Safety Factor of the Euler Buckling Force for the beams in the second stage of Lattice Optimization.
Parameter | Values | Description |
BUCKSF | Real ≥ 0.0 Default = 1.0 |
The specified Real value
is multiplied to the applied buckling force on the lattice beam to
provide a way to add a Safety Factor to Euler Buckling
checks. Therefore, in the second stage, the radii of the tapered beams are adjusted to handle the revised buckling loads based on the specified BUCKSF safety factor. |
