MBMNTE
Bulk Data Entry Defines an expression moment at a grid point by specifying a vector.
MBMNTE | SID | G1 | CID | EID | G3/N1 | N2 | N3 | G2 |
MBMNT | 3 | 345 | 4 | 0.0 | 1.0 | 0.0 |
SID | Load set identification
number. No default (Integer > 0) |
G1 | Grid point identification
number where the action force is applied. No default (Integer > 0) |
CID | Coordinate system
identification number. Blank or 0 infer the basic coordinate
system. Default = 0 (Integer ≥ 0, or blank) |
EID | Expression identification
number of the MBVAR entry
that gives the load measured in the coordinate system defined by
CID. No default (Integer > 0) |
G3 | Grid point identification
number to optionally supply N1,
N2, N3 in conjunction with
G1. (Integer > 0) |
N1, N2, N3 | Defines the direction of
the force vector. At least one of the vector components must be
non-zero. Default = 0.0 (Real) |
G2 | Grid point identification
number where the reaction force is applied. If blank or zero, the
force is an action-only force. Default = 0 (Integer ≥ 0) |
